Question about NAD C372 Amplifier
I have and old NAD C 320 with all of a sudden started to produce a burning smell and smoke. It definitely was not overheating; I was not even using it at the time it was just turned on. Now onlt the red light will show and when it is life on for only a short while there?s a pop sound and more smoke. I have opened it up and there is no obvious problem. Fuses are all ok etc. what on earth is the problem?
    Habit-Forming:
  • 21 Answers
You'll need to take it in and have an electronics technician fix it. Sounds like it has popped a channel. Sometimes it just happens.
But you might also check your speaker wiring. Sometimes it gets frayed and shorts, which will strain the outputs and sometimes cause damage that doesn't immediately kill the output transistors.
This is not customer serviceable.
Steve Greenfield
Electronic Engineering Technician student
Electronic Technician 20+ years
CET Computers and Consumer Electronics
IPC-A-610D CIS Specialist
Posted on Feb 06, 2010
Intercooled 3.1 1996 horizson. replaced turbo. still getting white smoke. water is overheating with in 10mins of driving. losing half to one litre oil.
the HONDA Horizon (Isuzu wonder box)
what engine. exactly .?
3.2 L 6VD1 SOHC V6
3.2 L 6VD1 DOHC V6
3.5 L 6VE1 DOHC V6
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4
x1 or G2?
floods, wot cranking cuts fuel and starts any flooded engine,
it's overheating that wins the First order failures rule sets.
nothing else matters. cure that first.! find cause! first.
sounds (im deaf there,lol) that smoke is out tail pipe end and dissipates fast and is not smoke but steam, , oil smoke smells like burning oil and lingers. steam smells sweet like burning Antifreeze.
AF steam is a blown head gasket or far worse.
do a compression test first to see if it's even worth fixing????
most are NOT. (unless free labor, sure)
first learn steam from smoke
serious , watch moms tea pot. see that steam goes away fast.and very uniquely , now watch burning oil.
remove dip stick, drop the drip of oil on hot exhaust manifold.
smell that, that is oil burning, and lingers.
this will last you a life time of blown engines..... just one look and bingo. (my instructor in 1965 did in front of class)
got oil in the AF/ CARBON chunks in same.
water in oil, ? pan, engine . milky oil.
rad leak down test fail? can be lots of reasons even a cracked block.or head. not just gaskets.
Mar 23, 2015 | 1996 Isuzu Trooper
Smell emitting from gas heater
Carbon monoxide is completely odourless and every sort of combustion of a carbon or hydrocarbon fuel produces carbon monoxide. That is why heaters should not be used without adequate and efficient ventilation and heaters should be kept in good order because efficient combustion produces less and inefficient combustion produces more.
Inefficient combustion and the need for service can often be recognised by the characteristic blue flame being tinged with yellow.
Heaters burning inefficiently often produce a smell for the sensitive or stinging eyes but that is not caused by carbon monoxide.
The gas itself is also odourless and the characteristic smell is added to warn people of leaks. I think the added gas smell tends to settle or separate from the liquid gas to some extent so there will be times when it is so concentrated it isn't entirely neutralised by the burning process, at least that is my theory.
Jun 18, 2017 | Heating & Cooling
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
1999 chevy blazer starts, but makes noise and no acceleration
Smoke coming out from the middle of the two rear tires right? Sound like your rear differential is out of lubricant. Leftover lubricant is probably getting burned by heat from the friction. Have your rear differential lubed up.
May 01, 2009 | 1999 Chevrolet Blazer
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
NAD C372 Amplifier Logo
179 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
