Green light on front of tv flashing and wont go off for two days now have unplugged and reset it but to no avail it still does not work model WS55813 I bought it about four years ago it only gets used about twice a week if that much and has gone several weeks with out being turned on
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
SOURCE: TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Posted on Nov 06, 2008
  • 1030 Answers
SOURCE: blinking green light on front
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Posted on Jan 15, 2009
  • 86 Answers
SOURCE: RCA D52W23 has shut off twice within the last week..
Try a power drain and monitor if the TV continues to do this or not:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve the issue, it's possible the power supply is on it's last legs.
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: Won't turn on. Constant blinking green light!
there is 4 caps on dm module
Posted on Apr 28, 2009
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green light on mitisubishi ws55813
error code. return to supplier. Possibly power supply
Dec 25, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Tv will not come on
I will need your model number in order to help you as well as need to know if the led blinks a certain number of times or is it a constant blink.
May 12, 2008 | Televison & Video
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Wont' turn on
The unit shutsdown for a reason ,is sensing trouble somewhere,it could be mechanical problem or an electronic problem,either way it needs service.An estimate will tell you whats wrong and if it is worth to you to repair.Good day
Sep 05, 2006 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
