Question about Maytag Washing Machines
Maytag 3000 series washer lock won't disengage
Maytag 3000 series washer Cannot get model number or serial number because door is locked.
the lock to this front loading washer will not disengage, and when I try to power it on, I get 3 quick beeps. This occurred after it went into spin cycle, and the legs were not level and it went into a thunderous vibration. By the time I got to it, it was shaking itself out of the washroom. I pushed the pause/play button to pause it, and it continued to spin until it finished the cycle after which, I disconnected the power. I tried to open it, and discovered it was still locked. I plugged it back in, lock will not disengage. I push the power button and all I get is 3 quick beeps.
  • spawnis Feb 06, 2010
    the power/cancel button gives 3 quick beeps and it is the only button that does anything at all. I can't see any watI'm going to head down to the self help shop to see if they have a wet/dry vac I can borrow and try that. thanks for the help. If you've got anything else I can try in the mean time that will be great
    I forgot to add that there does not appear to be any water inside the...washer drum? Thanks again.
  • 767 Answers
If you unplugg the machine for thirty minutes and plugg it back in it should release but it may lock back up after running a cycle it sounds like something got jammed in the wax motor that won't let the door release. Before unplugging it you coul also try holding down the pause cancel buttons for 60 seconds if this does not work unplugg it for 30 minutes and see if it releases.
Posted on Feb 06, 2010
100 series clothes washer not spinning
I don't see a question but you may find help at the link below.
If you need to buy parts or diagrams try searspartsdirect.com
Have your model number ready.
maytag washer won spin YouTube
Jul 24, 2014 | Maytag Clothes Washer Door Lock Switch...
Amana NFW 7200 TW door won't close because lock is engaged
You door lock is bad and needs to be changed. Without the proper model number I can't really give you accurate instructions
Jun 22, 2012 | Amana NFW7300WW Washer
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
I have a Maytag Neptune Model #: MAH5500BWW Serial #: 74920520ZZ The door refuses to close. If I slam it a few times, it eventually closes, locks, and it washes fine. I was considering replacing the lock...
If definitely sounds like you have a door latch problem. Slamming the door repeatedly, however, is probably doing more harm than good. You may be able to get the door to work intermittently for now, but eventually, the lock will stop working altogether.
You are correct. The part numbers ARE based on the Serial Number (series) when it comes to Maytag appliances. If a series is listed next to a part (series 10, for example), the part applies to all appliances that have a serial number beginning with "10" or higher. If an additional series is listed (20, for example), the part applies to all appliance that have a serial number beginning with "20" and higher.
EXAMPLE:
Series 10 (serial numbers beginning with "10 to "19")
Series 20 (serial numbers beginning with "20" to "29")
Series 30 (serial numbers beginning with "30 to "39")
So...using YOUR appliance serial number for this example, if you had a part that had several series listings, you would use the one that matches nearest to your serial number. Say, for example you had a door latch that had three different versions (series 10, 20 and 30). You would use series 30, as the number is the closest to the beginning two digits in your serial number. If your serial number began with "19", for example, you would use series "10", because the first two digits in your serial number do not exceed "20". If only one series number is listed, or if no series number is listed, it applies to ALL washers under that particular model number regardless of serial number. Confused now? So am I.
Based on the information you've provided, the part number for a replacement latch assembly for your washer is: 22004435.
You can purchase replacement parts at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also inclide helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. There are also helpful wiring diagrams included on some sites. Prices vary, so shop and compare.
NOTE: If your model number is not listed on some sites, use the part number from the Sears site as your search criteria. Sometimes certain model numbers do not always appear on parts websites (due to the appliance being too old, recently added model, etc.), but the part numbers generally will, because many parts are interchangeable between model numbers. If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Door remains locked after cycle and displays LO on screen
Try pushing in on the door slightly incase something is in the way inside the washer. If that does not help, you will need to manually open the door with the emergency pull cord. Once the door is opened you will need to have the door lock assembly checked to determine the cause of the failure. If the door latch needs replaced there are 2 available depending on the serial number. Part number 22003593 price $65.86 is for series up to 10, 22004435 price $87.48 is for series up to B4, compare to the first 2 digits of the serial number to choose the right part number.
Please see the images provided below for more details & instructions on replacing the door lock assembly if needed.
Feb 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
Wont complete the cycle reads Lr how do i unlock the door
maytag had many problems with this issue. "Lr" is a locked rotor in the motor. there is actually a motor control conversion kit maytag put out to fix this issue. And depending on the series number (first to numbers in the serial #) of your washer, there is a 10 year warranty for this kit. the kit is a new dc motor, motor control board, and harness. you should call maytag to see if you machine qualifies for this, the kits are expensive if you have to buy it. if you door wont unlock, and you need to get cloths out, open the lid for the detergent. look on the right side and the front inside where you put detergent in. you will see a green or red cord, that is the door lock release. if you pull on it, it will unlock the door, just dont pull to hard. good luck, shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
Washing Machines Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
