Question about Car Audio & Video
Car alarm programing
Hi there i have a hornet 477t car alarm and i would like to no set it to close windows and sun roof (full closing) thanks
  • 1 more comment
  • andy 93 Feb 22, 2008
    vw golf 4, 1.6 s, 1999
    all done and working thanks alot for your help, have a day,A+++++++
  • Christopher Renner
    Christopher Renner May 11, 2010
    What's the year/make/model of your vehicle?
  • 43 Answers
Assuming the following -
1. Your key, when turned to lock or unlock in the driver's door key cylinder and held there, will roll the windows/sunroof up or down respectively,
2. The transmitter on your car locks and unlocks the doors just fine.
3. You know where the valet switch for your alarm is located.
Program as follows:
Open the door and leave it open until you've finished programming. Turn the ignition on and off. Push the Valet switch and release it 10 times, and push it an 11th time making sure to hold it in. You should see 10 flashes on the status LED, 10 siren chirps, or both. This tells you that you are in option 10, which is the comfort closure feature.
At this point push the unlock button on the transmitter. That will change the comfort closure setting to "on". Once the unlock button is pushed the LED should stop flashing. At this point it is programmed and you can turn the ignition on again.
Posted on Feb 22, 2008
2000 Buick regal sunroof won't close any suggestions
Could be due to failure of the sun roof switch, the limit switch module, the sun roof actuator, the sunroof module or the 30A PWR WINDOWS PWR SUN ROOF CIRCUIT BREAKER in the I/P fuse block.
Sep 18, 2016 | 2000 Buick Regal
Can't start truck after battery change or unlock the doors
turn ignition switch on position for 20 seconds then try to lock and unlock doors.if you have sun roof open sun roof fully then close sun roof fully. then switch off ignition switch then try to start.
May 22, 2013 | Land Rover Range Rover Cars & Trucks
My sun roof just opens up wards to vent after installing a alarm my sun roof slid all the open two times & now it only opens to vent
For sunroof related problem,if your exact car model is provided,then it will be better.But in this case,i suggest you to check the link below:----How to Remove Power Sunroof on Acura Integra? http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-power-sunroof-on-acura.html
------------How to manually close Sunroof on 2000 Lincoln Navigator? http://technoanswers.blogspot.com/2012/01/how-to-manually-close-sunroof-on-2000.html
-----------No power to Courtesy Lights and sunroof? http://technoanswers.blogspot.com/2012/01/no-power-to-courtesy-lights-and-sunroof.html
-----------This will help.Thanks.
Feb 07, 2012 | Cars & Trucks
The sun roof won't close all the way shut. it opens ok and closes but won't lock shut
there shoulde be a hand crank (looks like a bent up allen wrench type thing) in the glove box...
there is a small hole in which it fits on the roof pannel... hand crank it tight to seal from inclimate weather.
Sounds like the switch is misalligned somehow.. and is stoping the glass short of full closed..
Open the glass full open and check the track area for debries and clear it out if there is any found.
use the tool to close the roof fully ...
Mar 31, 2011 | 1998 Chevrolet Cavalier
Hi , i have a 2005 bmw x5 . the panoramic sun roof will close correctly , the rear of the two sun roofs will not close , as if it has come of the runner. i can not find a company who specialise in this...
You can use my modification instructions, it will work for the X5 too. Take the download (pdf version 2) of thread 14 of below link: http://forums.5series.net/topic/96566-e61-panorama-sunroof-issues/
Success!
TFHODD
Nov 21, 2010 | 2005 BMW X5
Sun Roof
i think you need a new motor for the sunroof
Jun 13, 2010 | 2001 Jaguar XJ8
Have 04 getz and sun roof wont work.stuck closed.has two control buttons,up and down and open close.thought cables jammed.popped motor off sunroof.motor only running one way.wont reverse.HELP PLEASE.
my apologies for delay in getting back to you.only just sorted this.turned out was the little control unit for sun roof causing problem.it is cable tied to the sun roof frame beside the sun roof motor and can only get at it by dropping the head cloth on one side.learned from a hyundi dealer the switches give a lot of bother,now and again the control units do too.many thanks.
Mar 19, 2010 | Hyundai Motor 2004 Accent
Sun roof leaks air when driving and will not close unless
The air coming in due to the elastic band which seal ,which prevent the air noise to come in.It is leaking somewhere,now what you have to do is to test where it is leaking,close the sun roof ,pour water on the sun roof see where it is leaking,The elastic is not fix well,see for it or u must see if the elastic have not been broken some where ...hope that help you and fix the problem
Aug 28, 2009 | 2006 Toyota Camry
Sun roof will nt close cant find the rite fuse
check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
Headliner must be removed to access motor.
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel water trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse
  • Circuitry
  • Accessory delay relay
  • Roof opening panel switch
  • The roof opening panel does not open or close
  • Roof opening panel adjustment.
  • Battery junction box (BJB) fuse.
  • Circuitry.
  • Roof opening panel switch.
  • Roof opening panel motor assembly.
  • Roof opening panel lifter assemblies.
  • The roof opening panel does not open or close — one direction only
  • Circuitry.
Apr 10, 2009 | 2003 Lincoln Navigator
Chrysler concorde sun roof stuck open!!
Check the fuses to start with. If they are fine it could be a broken switch or a burnt electrical motor. If the closing mechanism has broken and bound up it could keep the window from closing. With the car in accessory mode or ON -whichever allows the windows to open - hit the close switch and listen closely. if a click of the motor can be heard it is a mechanical issue - if not it is electrical.
Feb 26, 2009 | 1998 Chrysler Concorde
Car Audio & Video Logo
404 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
