Question about RTO Buyers Salt Dogg Suvpro Tailgate Spreader Fertilize
Error code Was using the tailgate spreader til an error code to check motor came up, what I found was there is no power going to hopper from control box, can this be fixed or do I need a new one
    President:
  • 2,030 Answers
Yes it can be fixed, just have to fond out if a wire got broken or disconnected. The control may have gone bad , but it doesnt happen very often.
Posted on Feb 06, 2010
Error code e000025-0100
overload with the motor or motor failure
1. Check conduction with FU2 on the DC Controller PCB
(UN09)
2. Check the harness/connector between the DC Controller
PCB (UN09/ J23) and PS06.
3. Replace the DC Controller PCB (UN09)
Check the harness toward the sensor
4. Check the Hopper Unit (Y)
5. Replace the Hopper Unit (Y).
Jun 13, 2015 | Canon imageRUNNER 2220i Grayscale Copier
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
E00020
Canon ir 9070 error 69
Dec 24, 2010 | Canon imageRUNNER 8500 Copier
Spreader roteltates on blast mode only
You have a rheostat problem, or you have a motor seizing up. Your in cab control has a dial that controls the speed ( thats the rheostat), If the motor is seizing you need to address that problem first. You can check it with a volt meter. disconnect the motor at the connector at the spreader ( back of truck), then stick the red in the red side and the black.... in the black side. Have someone start the spreader on "blast" ( you should read 12 volts), then back it down to setting 5 and you should read around 6 volts, and 2.5 on the dial should read about 3 volts and so on. If this is working you have a motor problem, If you dont see the different voltage reading you have a problem in you cab controls.
Hope this helps
Nov 11, 2010 | Meyer Tailgate Spreader 240Lb Capacity...
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
RTO Buyers Salt Dogg Suvpro Tailgate Spreader Fertilize Logo
722 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
