Question about Compaq Presario Notebook
I have a Compaq notebook and the keyboard is not working under the administrator. It works fine under any other user. I've tried to update and uninstall drivers with no success. Also I cannot hit ctrl+alt+delete.
  • Compaq Master
  • 1,183 Answers
if the keyboard is working in any other user account . The user account has gone corrupt. You can recreate a new admin account. But before you do that back up all the my documents folder.
1. Restart the computer and press the F8 key a couple of times before windows starts
2. Select safe mode and press enter
3. Select the admin account and log in
4. Click on Yes to continue to work in safe mode
create new account in windows Xp
http://www.microsoft.com/windowsxp/using/setup/winxp/accounts.mspx
Create a new account using windows vista
http://windows.microsoft.com/en-us/windows-vista/Fix-a-corrupted-user-profile
Once the new account is created you and delete the old admin account
Thanks
Proton
Posted on Feb 06, 2010
Hp elitebook 2530p keyboard not working on administrator account but working on guest account
Spywares or virus has affected registry and keyboard input program BIOS.....
Open the administrator and create a new user account with the help of on-screen-keyboard.
make sure tht the computer is malware free.....
Install good antivirus and antimalware software with recent updates.
Apr 07, 2014 | HP EliteBook 2530p Notebook
Need the bios password on my gateway solo 9500
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
Has hdd password that i cant reminber any way to remove it
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Sep 24, 2011 | Computers & Internet
Hi the "F" keys on
Hi Friend, In this case I would recommend you to please try and connect any external keyboard to the laptop and check if the "F" key works from the external one
If it works it means that there is a need to replace the keyboard of the system If it still doesn't work then it means that there is a need to update the drivers for the system
NOTE: Please make sure that some dust is not stuck in the under the key
Dec 09, 2010 | HP Compaq nx6110 Notebook
Function keys f3, f4, f8, f9 and f10 are not working all drivers are updated using Compaq 6510b XP sp. 3
try checking the ribbon for the keyboard. there should be plenty of service manuals for removing the keyboard. usualy its screws on the bottom that look like the standard keyboard symbol. if that doesnt work you most likely need to replace the keyboard. they can be found on ebay pretty inexpensive
Nov 13, 2009 | HP Compaq 6510b PC Notebook
My Right side SHIFT-KEY on a keyboard of HP-Compaq nx5000 Notebook is not working. Is there any solution?
maybe the under-button rubber is corupted try to clean it
also u can use the left one for a while.
Jun 05, 2009 | HP Compaq nx5000 Notebook
I have a HP compaq laptop and cant log on as administrator
Hi martyn,
Probably the user profile is corrupted.
Log in to any account and type cmd in the start search bar > now right click on the cmd listed and select run as administrator. Now at the command prompt type net users administrator /active
This will activate the super administrator account. Now log in with this account and make any changes as required.
Hope this helps,
Anup
Apr 10, 2009 | HP Compaq 6720s Notebook
Administrator
By default Administrator account is disable in vista. while you are install window first user work as Administrator member...
Apr 01, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Compaq Presario C700 keyboard malfunction
What's your Operating System.
If you haven't tried it shutdown the computer then restart it.
I would restore the system to an earlier state.
In Windows XP you would go to Start - All Programs - Accessories - System Tools - System Restore
Follow the Directions and pick a restore date before your problem occured.
This should work.
Since you say that your mom's user works fine with the original keyboard, you can create a new user copy your files to that user and get rid of the old one.
Sep 07, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario v6000 laptop keyboard malfunction
Try reseting the BIOS to its defaults by following the instructions below :
Start or restart the Notebook and start tapping the F10 key immideatly you see the HP logo.
Now, in this press the F9 key to load the BIOS Default settings.
Press the F10 key to save the settings and exit the BIOS setup window.
Additionally, check by connecting any USB Keyboard to the Notebook if available.
Additionally, find the Product Number of the Notebook which is indicated with P/N printed on a white sticker pasted at the bottom of the notebook.
Open HP.com and enter this in the search field at the top right column.
Click on Software & Driver downloads and select the Operating System in the Notebook which should be Vista.
Scroll down to find BIOS under which you will find the BIOS Updates available for your Notebook.
Download and save the latest BIOS Update available.
Close all the windows and applications and double click on the file to update the BIOS.
Donot attempt to access any application or turn it off or restart when the BIOS is being updated as this will damage the BIOS Chip and make the Notebook useless.
The Notebook will restart automatically after the BIOS is Updated.
Hope this helps...
Jul 27, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario Notebook Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
