Question about Sharp LC46SB54U 46 in. LCD TV
I have an Lc-46D65U lcd sharp aquos,but suddenly the channel changer on the remote and the Tv stopped working. whenever I hit the channel I get the message, "no-input-selector -available". Help!
SOURCE: Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Posted on Sep 29, 2008
  • 22 Answers
SOURCE: can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Posted on Dec 17, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
How do I remove the back cover of a Sharp AQUOS LC-46D65U LCD TV? I have all the screws out but the section for all the plugins is stopping progress.
If you have removed the base, then remove the speaker compartment which has a lock that holds the plugins part. I repaired a similar tv today at my work shop.
Nov 16, 2016 | Sharp Televison & Video
Sharp Aquos 32 LCD freezes on air channel
I had the same problem, same channel, same day. It must be a problem with signal strength. With the TV on, I unplugged the coax cable that leads to my antenna (I am not on cable). As soon as I disconnected the antenna, I could change the channel off of 11.1. I plugged the antenna back in and all other channels work. Hope this helps.
Jan 27, 2013 | Sharp Aquos LC-32D42 TV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-37AD5E
Check componets around MCU (crystal and other capacitors)as well as bad solders on the mainboard.
Feb 04, 2010 | Sharp Aquos LC-37AD1E 37 in. LCD...
No input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Dec 29, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC46SB54U 46 in. LCD TV Logo
106 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
