Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Resolution is slightly off after gaming
I have my monitor set to 1280 x 960. This was perfect for a while but now after i exit a game i was playing it cuts the time off on the right side. The only way i could figure out of fixing it was going into the menu and choosing factory preset. This is only a temp fix though. Still stretches when i exit a game.
  • BlitzofWrath Feb 22, 2008
    Ive updated my drivers and it still doesnt work. It keeps stretching past the monitors boundaries anytime i exit out of something full screened.
  • BlitzofWrath Feb 23, 2008
    Im not very tech savvy. How do i do all that? Video card is nvidia geforce 8600 and im using XP
  • 981 Answers
It isn't your monitor, it is your display driver and settings.
Posted on Feb 22, 2008
  • Steve Nordquist
    Steve Nordquist Feb 23, 2008
    DirectX pulls stuff like that all right. Go on into the settings for that and gently tell it that it should reset on exit and not consider lower resolutions etc. on exit; that is to say, what is happening is that it is slacking on what it changes and restores when it pulls this on you, and that it's the driver and DirectX. You may even be able to cure this by selecting a different resolution for the game (in the game or its configuration files, if not the driver's list of valid screenmodes.)
    If you let on what your videocard is and what OS/VM you're using I bet you can get a more specific remedy; here or at another search service.
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 |
I have a problem with the resolution of the monitor when i open a game in order to play the resolution of the monitor become small help me please
Depending on what the game is, go to the settings within the game, go to display, and find the "resolution" setting and change to your liking
Aug 13, 2013 | HP Compaq 6715b Notebook
While playing starcraft 2, the computer screen flashes random colors and then freezes. It also makes a strange smell.
Not sure about the smell as this may be an indicator of a failing monitor and should be used with caution.. Otherwise it sounds like when you start up the game, it is changing the resolution to a setting that your monitor can not support. Please check you monitors resolution settings and make sure they are set the same as in Option in your game.
May 23, 2011 | Computers & Internet
When i start playing certain games, my monitor suddenly says no signal and turns black. However, i could still hear the music of the game in the background yet can't control a thing. When i perform a...
It has something to do with your screen resolution. Maybe the games resolution is higher that what your monitor can use. Under your game settings, look for Options> Video> Resoltion, set it to 800x600 and try to play again. If it works, then adjust it to a higher resolution.
Feb 14, 2011 | Computers & Internet
When i play a game the monitor goes into power save mode and will not come out .i have a Alienware Aurora with a dell st 2410 monitor
This is usually due to a resolution problem. see if you can reset the settings to default in the game. sounds like you are trying to play game in a resolution the monitor doesn't support.
Nov 04, 2010 | Computers & Internet
Moved from tv to pc and now all games show at half screen, internet, and email all work perfect.
Get into the game setting s and reset the resolution to match the computers. This will reset the resolution if it is froze. Do the same with the pc, make sure your resolution settings are the same or as you want them to be. Try to keep your game resolutions close to the native resolution for your monitor when connected to the pc.
Nov 30, 2009 | Computers & Internet
Acer X193w-- input not supported..
This is likely a screen resolution issue.
That monitor has a native resolution of 1440x900 (I used to have one). If the game is feeding the monitor too high a resolution, the monitor can't display it and.....input not supported. So, if the game has a configuration option (without going into the game itself) set the resolution to 800x600 and try to play. If it works, bump up the resolution until it looks acceptable.
Hope this helps!
Aug 21, 2009 | Acer AL1916W 19" LCD Monitor
Make sure Resolution is 1440 x 900......
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
71 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
