Question about Dell Latitude C400 Notebook
How to install windwosXP pro with an external USB cd-rw? since the original windows on the HD was damaged and can not boot any more.
  • Dell Master
  • 1,183 Answers
HI,
1. You need to connect the USB optical drive to the laptop.
2. Restart the laptop at the Dell logo screen press the F12 key a couple of times
3. You would see the one time boot menu.using the down arrow is select USB
4. Insert the windows xp cd in the optical drive
5. Press the space bar when you see the message "Press any key to boot from the cd"
6. Follow the screen prompts after the same.
In case you need more help on how to reinstall the OS . Please revert back
Thanks
Proton
Posted on Feb 06, 2010
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
My Maxtor Onetouch 4 500gb external hard drive is not working, the light does not come on any more as if there is no power. When I tried a universal power cord the light blinks really fast, but my computer...
First thing you need to do is to confirm your Power supply is working, i think its a 12 volt adaptor so check wattage rating and then try to power a router or a device that uses the same voltage and wattage with it, an easier way is to check whether the light blinks once very fast right when you stick the adaptor into the external HD's back, if it does, download hyrens Boot CD from thepiratebay.org and burn it to CD...Most of the tools on Hyrens boot CD work in DOS but a limited amount works in windows, try booting into windows and try using the partition recovery tools like undelete etc, if this does not work you will have to take the actual HD out from the case by dissassembling it and then plug the actual HD without the case straight into your pc via sata cable, restart your pc and instead of booting windows boot the hyrens boot CD Menu, now use the partition and HD checking tools, this should work, if it does not, your HD is irreparably damaged and you might need to mail it to data recovery experts to get your original data back, Hope this helps..
Oct 28, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Can't boot from USB (No CD Drive) for fresh install
Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
Dec 05, 2009 | Toshiba Portege 7100 Notebook
Fujitsu Lifebook P1120 Won't Boot To CD\DVD
Fujitsu seems to have secretly added a Hardware black list for Booting USB DVD-rw.CD-rw drives.
I have a Stylistic ST5032D slate.
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Oct 03, 2009 | Fujitsu LifeBook P1120 Tablet PC
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
Run windows xp from external hard drive
you can install windows in external hard drive..but after installation u have to make change in BIOS as 1st boot device as USB.....
Dec 12, 2008 | Lenovo T400 Notebook
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Compaq Armada E500 Notebook
External USB DVD-RW
Hi Nick,
this may be a driver conflict issue, either with your factory fitted drive.
try going into system/device manager and see if its in there, click remove or uninstall, reboot and plug the drive in again, go through the add new hardware wizard if need be.
the other suggestion, is to remove all USB devices from The device manager, reboot and the system will re-install the USB port drivers.
Mike @ compurepair.
Jan 17, 2008 | Computers & Internet
Dell Latitude C400 Notebook Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
