Question about Linksys Wireless-G WRT54GS Router (e125894)
Router has stopped working
When i attach my cable fom my broadband modem there is no signal no lights flashing therefor unable to connect my laptop to wireless internet
    Novelist:
  • 142 Answers
Reset router
Posted on Feb 21, 2008
No signal/low signal
Unplug your router and unplug your cable modem,Turn your cable modem back on and wait for the lights to stop flashing.The plug your router back into your cable modem.Once the router lights stop blinking try to connect.If you still have a weak signal call your cable provider and ask them to reboot your cable modem at their end.
Apr 10, 2014 | NetGear Computers & Internet
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Apr 15, 2010 | Computers & Internet
I have a Dynamode wireless router which i have configured however the cable which came with it does not fit into telephone connection. What other cable do i require
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
Sep 08, 2009 | Computers & Internet
I lose broadband once I diconnect the ethernet cable
you are providing the username and password from your laptop. So its disconnectiong when you shutdown your laptop
Try to use the username and pass from the Modem itself .
Hope you can find difference. Thanks
Dec 12, 2008 | Computers & Internet
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
My Wireless internet card don't work
i think you are a little confused, your laptop may have a wireless card internally, but you need a wireless broadband or cable router for the wireless adapter to pick up a signal.
A fax modem cannot be wireless and cannot be broadband as you cannot fax using a broadband connection.
Assuming you have a broadband connection you will need a wireless modem/ router or roter connected to a broadband modem, not a standard 56k dialup modem as they aren't wireless or broadband.
Nov 08, 2007 | Toshiba Satellite A60 Notebook
Linksys Wireless-G WRT54GS Router (e125894) Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
