Question about Spa Parts Plus GFCI, Circuit Breaker, 30 Amp
Need electrical diagram on connecting gfci to switch to light to switch Putting in a gfci receptical in bathroom connected to switch to light to switch. Can you help me please.
    Novelist:
  • 101 Answers
This can be confusing, but basically, you will need to get a hot wire to the GFI receptacle. If you get a wire from a switch, you need to splice into the hot wire - not the other one (which is a switch leg). You will also need to get a neutral wire to the GFI recept. You normally won't find this at a switch, because you never run a neutral to a switch. The only exception is when there's a light on the switch itself. But let's not get confused with this. There's no neutral at a switch. So your best bet would be to get your hot and neutral from another receptacle. Or, you can get your hot and neutral wire from your electrical panel. Its very important that you do this correctly, otherwise you can cause other problems. I hope this helps you out a little. If you have more questions, feel free to contact me. Good Luck to you, and I hope this works for you. - Jim
Posted on Apr 05, 2010
20A125/250V wire diagram
I've copied instructions from an Amazon review.
worse than worthless and border on dangerous. Be forewarned, and allow some time to install it correctly; and don't expect any help from the included paperwork.
IMPORTANT THINGS TO KNOW:
- There is no ON/OFF indicated on the switch or the instructions, so there is no way to know which direction is on or off. The picture included is upside down, and shown in the OFF position. If you install it with the switch on top, it will work intuitively with the switch up for ON and down for OFF. (Should be common sense, but doesn't say it anywhere, and the text on the device and photo suggests otherwise.)
In short, here's what the directions should say:
Before you begin -> Leave yellow sticker over top connections unless you want to add downstream GFCI protected outlets/lights - that's straightforward.
1) Strip all connections to 1/2", and use the holes on back of receptacle for direct connection.
2) Connect wires from breaker into terminals in back of switch/outlet. (Hot=Black-Gold; Neutral=White-Silver)
3) Connect white wire from light into extra hole next to the white wire from breaker.
4) Connect one short black wire from outlet into the hole next to black wire from breaker.
(this means all four holes are now filled)
5) Connect remaining black wire sticking out of receptacle directly to the black wire from your light.
6) Ensure all ground lines are properly connected.
7) Push into box, install cover plate and enjoy.
NOTE: This will result in the GFCI working properly, with no GFCI protection for the light. This is the recommended install, so that if the GFCI trips you won't be in the dark. If you want GFCI protection for the light as well, simply modify step 4 and insert the black pigtail into the hot terminal under the sticker.
The directions offer myriad ways to connect this, but are incredibly hard to decipher because the text does not agree with the diagrams. I believe that diagram B1 was the one that 95% of people will need...
Jun 06, 2014 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
Installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
I am trying to power a bathroom fan and lite combonation from a GFCI that is located in the next room. I've taken power from the load side of the receptical , why won't it work ? Is it because all...
If you have a GFCI recepticle with 8 holes in the back. hook your fan to the two holes on the "line" side. If you don't have four holes to use tail, join the line wires, with a tail to hook to the line side of the recepticle. This way you have a direct power to the fan and protected circuit to the recepticles.. Make sure your connections are good. If using the "holes" make sure you tighten with a screw driver and not just a screw gun.
Jun 22, 2011 | Oregon Scientific Home
Bathroom switch controls light & fan. Trying to change out switch into a gfi switch/receptile. Box contains 2 wires ( total 2 white and 2 black, plus ground). what do i do
First you have to identify cables.
You have 2 cables that enter box. Each cable has black and white wires.
One cable probably comes from breaker box, and one cable probably goes to Load (which means your fan-light)
Separate wires for testing. Turn power ON.
Test each wire to bare ground wire. Tester lights up on Hot wire. This wire will connect to brass 'Line' screw on back of new GFCI device.
Hot is identified. Test Hot to all other wires except bare ground. Tester lights up on Neutral wire. Neutral connects to silver screw that sits across from Line screw on new GFCI device.
Other two wires inside box go to Load.
These wires connect to the two wires that stick out on back of new GFCI device.
Ground wires are connected together and connect to green screw on new device.
Apr 21, 2011 | Cooper Wiring Devices ACE AC-DC...
I have a black/white/ground wire coming from my power supply into my bathroom. I want to install a 274w combination device so as I can have one plug outlet and a switch for the shower fan.I need to see a...
1) In this situation we need to test the wires.
Electricians don't guess, they test, and a diagram would be guessing which wire color does what.
2) FYI: non-GFCI receptacle located in bathroom is not code, and device will have to be replaced when property is sold. The reason for GFCI is the likelihood of you holding defective electrical gizmo from China in one hand while putting other hand in running water. Or electrical gizmo falling into bathtub occupied by wife with large life insurance policy.
If you have kids using that bathroom, I want you to avoid using non-GFCI device.
3) Your new device has color-coded screws: Dark, brass, and silver.
These colors tell electrician how to wire the device.
4) Let's test to see which wire connects to which screw:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Turn power ON.
Tester lights up on Hot wire. Hot wire connects to dark-colored screw on device.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to silver screw, and will complete circuit to receptacle.
If box does not have a Neutral wire, the circuit to receptacle can be completed using ground wire on silver screw, but I am not recommending that.
Last wire goes to Load (light, fan, motor). Load wire connects to brass screw, and will complete circuit to Load.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electrical device.
Leviton and Lutron both make GFCI switch-outlet combo.
Buy at Home Center or on-line
Leviton 7299
http://www.amazon.com/Leviton-7299-NI-15-Amp-125-Volt-Combination/dp/B000UJADW6
Jan 02, 2011 | Cooper Industries Cooper Wiring 274W...
I have an electric box in my bathroom. This box has one cable coming in (one black and one white wire) and powers a light switch and a GFCI plug. My wall had a leak and fried the GFCI so I bought a new...
You have a combo light switch and GFCI.
It sounds like you are 1 wire short.
Where is the wire that goes to the light?
The black wire should be Hot, the white wire could be the Neutral or the could be the wire going to light.
The Black hot wire connects to dark-colored or brass screw on one side of device. This screw should be labeled Line.
You need a white Neutral line that connects on silver-colored screw that is located opposite where black wire connected.
The switch controls a light ... but you need another wire going to the switch.
Add a comment. Post a photo on Imgur.com and add that to your comment.
Nov 21, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
If you have 3 white and 3 black as well as a ground,how do you hook it up ?
If I understand correctly, your are replacing a GFCI receptacle with another GFCI receptacle
And your existing GFCI has 3 black and 3 white wires
And there is not a switch involved in the changeover.
I downloaded the manual from Lutron
http://classic.lutron.com/CMS400/techinfopage.aspx?id=22163
Every wiring diagram in manual shows:
Black wires connect to brass-colored screws
White wires connect to silver-colored screws
The brass and silver colored screws are typical of all residential receptacles. The color-code tells the electrician which terminal gets the black and white wires.
Are you having a problem putting 3 wires onto 2 screws?
It is a common problem.
You can buy a short piece of white and black wire at hardware store
Lets work on the black wires as example:
Strip back insulation on short piece of black wire
Hold together two of your black wires and start twisting them together
Now add the short wire to the two black wires you started twisting
Now twist together the two blacks and short black
So three wires are twisted together and you have a short lead that can connect to screw on GFCI
Put a wire nut over the twisted wire
Now you're ready to connect other end of short black wire to brass-colored screw
This reduces the number of wires that connect to screws
http://waterheatertimer.org/How-to-twist-electric-wire.html
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Oct 20, 2010 | Lutron NTR-20-GFCI VAREO 20A GFCI...
Master bathroom: GFCI combination outlet/switch to a dimmer to 3 recessed lights. I am not an electrician but I've wired most of the house myself with advice and Internet diagrams. This GFCI combo to a...
Dave, So you have a GFCI outlet, and a 3way switch and a 3way dimmer switch, right? First off, if you want the GFCI to protect the switches & light you will use both output terminals of the GFCI which have tape over them. The white wire (from the silver screw output of the GFCI) will go to the lights, passing through the switch boxes, but not connecting to anything. The black wire (from the brass screw output of the GFCI) will feed the first switch. Both the switch and the dimmer must have 3 terminals (plus ground). One terminal is the input/output, the other two are "travelers". On a full size switch the input/output will be on the top and the two travelers will be on the bottom (or upside down from this - the key is that the travelers will be on two sides of the switch but on one end. There will be 3 wires (plus ground) going between the two switch boxes 1-the neutral which does not connect to either switch, 2,3 the two travelers. Connect the two traveler wires to the two traveler terminals on the dimmer. The other terminal on the dimmer is the hot wire output to the lights. I hope you found this helpful. Good luck
Aug 17, 2010 | Home
How do I wire a leviton 7299 combo switch. I have power to the box from standard 3 wire cable blk and wht with a grn ground. I then have another cable again blk/wht with a grn ground going to a set of...
Ok this is a GFCI switch receptacle combo. You will connect the incoming cable to the incoming terminals on the Recptacle. White goes to Line (silver) terminal Blk goes to Line (brass) terminal. For the light connect the white to the load terminal (silver) Then take a short black wire and connect from the Load (brass) terminal to one of the switch therminals. Connect the remaining outgoing black wire to the other switch terminal (at bottom of switch) connect both green wires to green ground screw. (best to "pigtail" ground wires so only one wire on terminal. This will give lights GFCI protection also good for hanging lights in a bathroom.
Aug 17, 2010 | Leviton R02-7299-0NW Switch And GFCI...
I replaced the light fixtures in 3 bathrooms that are all on the same connection and now when I turn one of the lights on it trips the gfci breaker.
The lights may all be on the same circuit, but are they all connected to the GFCI (as in if you hit the test button do all the lights go off with the GFCI)? If so that's ok, but not really necessary. The places you see lights connected to GFCI's are in bathroom lighting where there is a built in receptacle in the light that can be used by someone. If it is only a light I see no reason for it to be connected, which brings me to my last point. If the lights are not connected to the GFCI the GFCI may still be drawing current from the circuit. A GFCI is a device that protects a person using anything plugged into it by sensing a rise in current. Many times a GFCI can be faulty or ultra senstive, where even the smallest amount of current can trip it. Replace your GFCI and the problem should fix itself. Just make sure to connect nothing to the side taped with yellow tape (the load side) if nothing was connected to the load side before (the lights would be connected here if they were before).
May 15, 2010 | Sylvania Circuit Breaker - Zinsco/ 50 Amp...
Spa Parts Plus GFCI, Circuit Breaker, 30 Amp Logo
426 people viewed this question
Top Spa Parts Plus Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
