Question about Samsung Eternity Cell Phone
Water damaged and it works but for some reason it keeps turning off, is there a way to fix water damage?
  • 316 Answers
Hello my friend,if the board and chips are oxidized now there is nothing you can do anymore.You should immediately open your mobile unplug everything and try to dry everything with a hairdressers gun and leave the battery and the Sim card out for some hours when you drop it into the water.
Posted on Feb 06, 2010
How to fix kurio 7 after dropped in water?
This is probably water damaged. You MIGHT get lucky with keeping it (powered off) in a bag of rice to wick the moisture out of the tablet and into the rice. Keep it there for a few days to keep it from getting damaged any further.
Jul 15, 2014 | Kurio Touch 4S Handheld
What can i do to fix water damage to my fifth generation ipod?
This question was asked about three weeks ago. Sorry for the late input. Rice may help and so does time. If it doesn't come back right away, you may need to give it plenty of time - as in days. I would keep it in a slightly warm place. Even if it doesn't seem to work, don't give up on it. It could come back after the battery is completely discharged. Don't try to charge it for a very long time (weeks) unless it shows signs of life to the point you are able to use it again.
Update us on what has happened so far. Did the rice work for you?
May 13, 2014 | Apple iPod 5th Generation
Is it worth trying to fix a maranz sr4200 with slight water damage
Probably not. Marantz does not supply replacement boards, so you can't just put a new board into it to replace what was damaged.
Apr 16, 2013 | Marantz Audio Players & Recorders
Keeps overheating
if your car keeps over heating, then it means the fan blowing the radiator is weak or might not be working at all.
Also, your water pump might be damaged, which can cause it to leak water. Put water into the radiator and check under the car to observe if there would be any leak of water.
Make sure the above is checked and fixed because thing overheating problem can damage your gasket which can make your can engine to knock.
Water as to be leaking from somewhere which is making the car overhear frequently.
Good luck.
Jan 02, 2011 | 2005 Nissan Sentra
NOKIA 6300 FELL IN WATER AND DEAD.CAN IT BE REPAIRED?
What to do is this,
Unscrew the phone,
Get a Methylated spirit and a brush,
Bring out the board of the phone and use the methylated spirit to brush off remaining water on phone.
Keep under heat to dry off,
After board is dried, fix it back and screw back phone.
Am sure after doing this phone will work well.
But if phone still doesn't work ,that means water has damage some component inside the phone.
You will need to consult a phone technician for assistance.
Take care.
Aug 11, 2010 | Nokia 6300 Cell Phone
Heated panel
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
May 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Camera will not turn on
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. Another reason is memory card. Remove the card & try. If your card is virus infected the also the couse of this reason. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Apr 04, 2010 | Kodak EasyShare M1033 Digital Camera
Kenmore refrigerator ice making not working
make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • May 21, 2009 | Refrigerators
    My car alarm goes off for no reason
    I have the same problem with my Z3 alarm going off, a local BMW specialist has traced it to the pitch sensor which has been damaged due to a water leak, the wires are also corroded. They have quoted £200 to fix it, but advise that the water leak is sealed first because it'll just get damaged again. I've had a look round and it appears the water is getting in by the off side light cluster via the boot gutter.
    Feb 27, 2009 | 1999 BMW Z3
    Samsung Eternity  Cell Phone Logo
    162 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Bill Long
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
