Question about Dryers
My whirlpool dryer kicks my breaker after running for about 40 minutes, the clothes are not dry yet when it kicks the breaker. It does this on the high and medium settings both. My husband replaced the "pigtail" and the 220 outlet it plugs into.
  • 4 Answers
Check your circuit breakers.Most of the time when breakers get older they can't hold the current load. Also make sure the wires that connect to the breakers in the main panel are tight in that circuit..Be careful I had a dryer that did the same thing. Check to make sure the lint is cleaned out so there is no obstructions that's creating a air flow problem. The dryer gets to hot and shuts down.Well that was my problem.Just an idea.
Posted on Feb 06, 2010
Whirlpool wed4815ew1. Timed Dry works, timer advances. Automatic Dry does not. Plenty of heat, clothes dry fine. Bought new timer W10185982 STILL doesn't advance
Hello David. We regret to hear about your Dryer not working on select cycles. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If that does not help then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
Whirlpool Dryer GEW9200LW1 skip digits when set to dry
If the clothing comes out dry within a normal time,usually 40 minutes or less. Whats happening is the computer is recatulacting the time remaining to dry a load of clothes as it senses they may still not completly dry or even will drop off some time if clotes are dry before time computer calculated at start of cycle.
Gene
Aug 16, 2011 | Whirlpool GEW9200L Electric Dryer
The clothes take forever to dry. Even with the more Dry cycle the clothes are wet after 40+ minutes The timing changes from 40 minutes then to one hour+.....
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Nov 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool dryer that has been blowing the breaker, and is not heating up to dry clothes
how long is it run when breaker is blown? element could be blown and shorting to the cabnet. motor could be full of lint
Jun 28, 2009 | Whirlpool LER4634J Electric Dryer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Dec 29, 2007 | Maytag HYE3658AY Electric Dryer
Dryers Logo
183 people viewed this question
Top Dryers Experts
