Question about Kirby G6 Bagged Upright Vacuum
Cleaning solution distribution problem
I connected the shampooer as instructed, however, when I began to shampoo, all of the solution came out in one spot, oversoaked one section, what did I do wrong?
  • Uplate May 11, 2010
    http://www.greatvacs.com/shampoo.shtml
    here is a link to step by step instructions on how to use your kirby shampooer.
    Remember to lower the kirby height selector to its lowest setting when shampooing.
    Hope this helps!!!
    were there any suds or was it mostly water?
    if there were little to no suds present i would check the mesh screen that is connected to the tank. It can be dislodged by the hose at times. The mesh screen is a small (about an inch in diameter) round piece of plastic with a mesh screen in the center. It is what produces the suds on the kirby shampooer.
    let me know if this solves your problem or if its something else
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Hope the above link was helpful!!!
Posted on Feb 24, 2008
Can I shampoo a couch?
Yes<br /> <h2 class="Heading1a Underline header"><span>Instructions</span></h2> <!-- google_ad_section_start() --> <div class="thingsYouNeed"> <h2 class="Heading5a">Things You'll Need:</h2> <ul> <li> <span>Vacuum and its hose attachments</span> </li> <li> <span>Shampoo specific to the couch's fabric</span> </li> <li> <span>Rug shampooer</span> </li> <li> <span>Steam cleaner, possibly</span> </li> <li> <span>Rag and cotton swabs</span> </li></ul> </div> <ol id="intelliTxt"> <h4 class="Heading4a">Preparing the Sofa</h4> <li id="jsArticleStep1"> Vacuum the sofa, its pillows and its cushions with the hose attachments. Do not forget the arm rests and backing of the couch. This will clean loose dust and dirt.<br /> </li> <li id="jsArticleStep2"> Dust the wood areas with a soft rag and a cotton swab for the area between the material and wood.<br /> </li> <li id="jsArticleStep3"> Find your warranty. If it is still in effect, the warranty may be null and void if you apply any cleaning solutions. Call the company for cleaning instructions.<br /> </li> <li id="jsArticleStep4"> Determine the sofa's fabric. This tag is typically found under the cushion area.<br /> </li> <li id="jsArticleStep5"> Buy shampoo specifically for your sofa's fabric.<br /> </li> <li id="jsArticleStep6"> Rent a rug shampooer.<br /> </li> <h4 class="Heading4a">Cleaning</h4> <li id="jsArticleStep1"> Assemble the shampooer according to its directions.<br /> </li> <li id="jsArticleStep2"> Test a small area of the sofa. The best place may be the back of the couch or under the couch if possible.<br /> </li> <li id="jsArticleStep3"> Clean the entire couch. This will prevent watermarks.<br /> </li> <li id="jsArticleStep4"> Allow it and all its parts to dry before reassembling the cushions and pillows.<br /> </li></ol> <div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;"><br /></div><br /> <!-- from fixya rte -->
Jun 12, 2010 | Kirby G6 Bagged Upright Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My kirby vac when using the shampooer doesn't distribute the solution
Make sure that the small round suds screen is in place on the shampoo tank where the hose connects to the tank.
Here is a step by step guide to help you out...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps...
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do i use my carpet shampoo system?
Please copy and paste the address below to the address window to obtain instructions for your Kirby Shampooer.
Hope this helps :)
Thank you for using Fixya!!!
May 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampoo not spreading evenly
Either you are not lowering the shampooer tray all the way down or maybe you lost the vinyl lip that is mounted on the front of the tray. Detailed shampoo instructions and pictures HERE.
Good Luck
Rocky
Apr 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
Vacuum brush roller with belt attached is off
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
