Question about Refrigerators
The light bulb blew in the refrigerator side of my side by side Model #GS5SHAXNQ, I HAVE TRIED 2 GOOD BULBS AND NEITHER ONE WILL WORK.
    Sergeant:
    Champion:
  • 263 Answers
Maytag model MSD2651HEW replaced two refer side lights. New ones will not light
some of the bulbs you buy at the stor the sucket pease is not long onoft try to scruit more or by them from a applice parts stor they little longet and make good contact
Feb 21, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Light bulb does not work
go to this site Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com put your model number in and you can look up your fridge,if you changed the bulb and it didn't work you could have a bad socket that the bulb goes into or a bad door switch,try pushing the door switch in and out to see if it will work or try unscrewing the bulb you might of not put it in staight or check the socket with a meter to make sure you have power there,go to that site you can look up the door switch and the socket if you need to order them,good luck
Feb 13, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Light bulb not working
Hi, I know this sound silly but, I go on a lot of service calls for the light bulb. Most of the time, all I have to do is give the bulb a half turn mre. They can feel tightened but, it might take a little more turn. I use a rag and grab the bulb with my fingers and the palm of my hand and twist.You might need to losen the bulb and try tightening it again.
I hope this helps you.
Vic
Jul 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Interior light
Hi. I've seen this situation on this model. The bulb is not screwed in all the way. You think it is but it is not. If it still doesn't work, get new bulb. Sounds like you got a couple bad bulbs. Good Luck, Mack
Mar 29, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Side by side ice and water dispenser
Did you replace the bulb with one of the same voltage rating?
Seems strange that a new bulb should blow straight away, maybe it was faulty.
This sounds like a blown fuse.
Oct 13, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
