Question about Singer 2639
Motor runs but does not sew, like the belt is off
The motor runs but does not sew, seems like the belt is not on. I only used the machine one time and it worked great, opened it this second time and I can rotate the dial and the needle goes up and down but when I press the foot pedal, the motor runs but the needle/arm does not go up and down.
Bobbin winder is engaged
Posted on Mar 24, 2011
My mom's old singer will start sewing then slows down to a stop.
It may need a REALLY thorough cleaning & oiling, Cindy, including the motor bearings. The motor's windings may be getting weak, too, or the new belt may be slipping.
Aug 11, 2014 | Singer Sewing Machines
Motor runs but belts not moving, How do I fix this?
First, give it a good cleaning and oiling. It may need some grease on the gears. If the belt is still not moving, it could be too loose...stretched out. In that case you would need to replace it. This seems pretty complicated. If the cleaning and oiling don't work, take it in for service. You can download your manual here:http://www.imarksweb.net/book/kenmore+158+14100+manual/
Jul 06, 2012 | Sewing Machines
Baby lock slows down to 0 after sewing a few inches
have you checked
1.to make sure it's plugged into the wall outlet good?
make sure the power & foot pedal are connected correctly to the machine?
2.does the motor smell in any way?
when was the last time it was serviced?
Feb 08, 2012 | Baby Lock Sewing Machines
Belt came off
well that is very nice idea you can fix with your self provide talls most commonly use.Set of screw driver,open and socket wrench,pliers etc...Remove the top cover plate by loosening bolt holding the cover and cover besides the handwheel where the motor was installed besure it was unplug from ac source(No power)Check the motor holder that attaching from casing.You can see the motor coupled by the belt.In the motor holder there is a bolt slot adjustment for tensioning belt tighning and loosening.If you want to disconnect the belt and replaced loosen the tension and pull out the belt.Sometime belt are sliping to the pulley it affect
the sewing machine operation,you can tighten from adjusting the tension of the belt.adjust not so tight after adjusting try to run manually first by turning handwheel freely if the motor will run freely with out obtruction no power supply.If your satiesfied try to run with power supply but jag twice first to be sure no problem occured before continous operation.
Mar 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 2639 Logo
379 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
