Question about Sunbeam Healthometer Body Fat and Weight Scale Stainless Steel
I just bought this type of scale and after setting it up successful, I turn it on, wait until I see 0.0, I get on it and instead of revealing my weight it turns off after 10 seconds?
  • 10,319 Answers
It has a 10 second delay then shuts off automaticly
Posted on Feb 06, 2010
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    How do I set up Netflix through my Wii?
    NETFLIX CUSTOMER SUPPORT PHONE:
    1-888-638-3549
    PRESS 0 AT EACH PROMPT.
    Average Wait: 5 mins - 24 hours, 7 days
    OR
    Netflix Calls You Instead
    http://gethuman.com/call-back/Netflix/
    http://www.netflix.com
    1-888-638-3549
    OR
    Aug 12, 2014 | Netflix
    Shows 0.0lb no weight
    Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
    Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
    I have a GoWalking by Sportline scale and right now it is set to kg but i need to set it to lbs how would i do that. i lost the manual pls help
    Press I/O button to turn on.
    While "1-10" is flashing, press "i" button once.
    Use up/down arrows to choose a 'user number' from one to ten, then press "i" button.
    Press up/down arrows to chose between male(bottom) and female(top) icons, then press "i" button.
    Use up/down arrows to specify your height in cm. (inches x 2.54) Press "i" button.
    Use up/down arrows to specify age, then press "i" button.
    "1-10" will flash again. Using up/down arrows select the user number you've programmed and wait for your height and gender to display, followed by "0 lb." You can now use the "i" button to toggle lb/kg or step on the scale for your weight and body fat %.
    Next time you turn the scale on, just use the up/down arrows to pick your user number then wait for the 0 display.
    Jul 07, 2010 | Health & Beauty
    Taylor 7532S, battery replaced, error message 0-Ld
    Try to reset the unit. Use the following steps
    - Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
    - Remove the battery from the compartment. Close the battery compartment door.
    - Sit the scale right side up on a hard surface floor.
    - Step on the scale and stand still on it for five to ten seconds. Step off the scale.
    - Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
    - Place the scale right side up on the hard surface floor.
    - Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
    - Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
    Hope this solution has been helpful?
    Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
    My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
    you have 4 button on this model
    1 tap the scale to start, it show 0.0
    2 tap set to set person and height, age ...( use set, up, down buttons )
    done
    when start use
    1 tap scale to start , show 0.0 again
    2 tap user again and again to choose your user
    3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
    i've been through becuase my friend lost his instruction manual.
    Now it wook
    Have Fun
    duccotam@yahoo.com.au
    Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
    Space button on samsung u410 keypad
    Texting using a keypad instead of a keyboard is not likely to be successful.
    Jan 09, 2018 | Verizon Communications Samsung SCH-U410...
    Err 4
    Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
    Error Codes for the 5757 (according to my manual):
    Er 0 Initialization error (remedy described above)
    Er 1 Instability error (step off the scale, then back on)
    Er 2 Overload warning (registering weight beyond the 440 pound max)
    Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
    Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
    Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
    Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
    Headlights shining high are the bulbs upside down
    it's very difficult to install them upside down,but i guess anything is possible. wait until dusk,shine the lights on a flat surface and attempt to adjust until the lights look like they are shining in the center.
    Apr 29, 2009 | 1998 Plymouth Voyager
    Changing user settings on Conair WW67T scale
    1. Tap the scale
    2. Wait for "0.0" display
    3. Set
    4. Use the up arrow then stop on the user you desire
    5. Set
    6 Using the up/down keys enter Height
    7 Set
    8 Using the up/down keys enter Age
    9 Set
    10 pick the little man or woman
    11. Press SET - the scales will redisplay your profile settings for verification.
    12. Wait Until the Display Goes Blank.
    13. Tap the Scale.
    14. Press USER, select desired profile, P-01 is the default.
    15. Wait for "0.0" display
    16. Step onto the scales and wait for all measurements to display
    Oct 02, 2008 | Health & Beauty
    Sunbeam Healthometer Body Fat and Weight Scale Stainless Steel Logo
    Top Sunbeam Health & Beauty Experts
    Kevin Hill
    Level 1 Expert
    musquodoboit
    musquodoboit
    Level 1 Expert
    Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
