Question about Dayton Tools & Hardware - Others
Daytona 1/2 hp 120 V. model 4K781W. ROTATION IS CCW WIRE # T1,T3,T8,T3,T4 & T8 WHAT WIRES ARE CONNECTED TO HOT BLK & COMMON WHT? JAMES MESSER GEN.JWM.M@GMAIL.COM
  • gen_jwm_m Feb 06, 2010
    Hi Heatman101,
    I assume the voltage connection is for 120 volt and 480 is your speciality.
    Thanks,
    Jim
  • Dayton Master
  • 43,501 Answers
Hi, for CCW rotation...
1,3,8, go on the black
2,4,5 go on the white.
to reverse rotation switch the 5 and 8 wires...
If it is a single voltage
1,8 black
4,5 white
3's together
http://www.electricmotorwarehouse.com/motor_connection_diagrams.htm
Heatman101
Posted on Feb 06, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Feb 07, 2010
    I have wired many motors of different voltages, both three pahse and single phase...
    There are many ways to wire motors and often the disgrams are right on the label of the motor.
    Being able to read them is difficult sometimes.
    Much of the info is searchable on the net though...
    Heatman101
  • D. Floyd Kolb
    I forgot the main point though..yes, those hookups I gave you are for 120v
    It depends if you have a dual 120/230 v motor are a sigle 120v only motor.
    Heatman101
Wiring a smith and jones 1 hp electric motor for 220. The diagram is not very helpful. I have a red and black hot lead and a white neutral. Where do they all go? I want to make the motor go ccw.
Ok from what I read on the diagram take one lead to P1 cap of P2 T3 T8 and T2 are together and T4 and T5 are put to the second lead
If you want to change direction exchange T5 and T8
Feb 11, 2017 | Smith Pool & Spa
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Need to rewire from 480 to 240 need coolant pump diagram for colchester # 348337 3 phase motor
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Jun 22, 2010 | Measuring Tools & Sensors
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
DOES ANYONE KNOW ALLGENERATOR WINDING RESISTANCES ?
5 Ohms at the rotor.
Disconnect all the stator wires and measure each one to ground, it should read opened.
Before disconnecting wires, mark which are hot and which are neutral. Measure between the hot neutral wires and some should read at least 0.5 ohms. You should have T1 and T2 reading 0.5 and T3 and T4 reading 0.5. T1 and T3 should read opened, T1 to T4 should read opened. Also, T2 to T3 should be opened and T2 to T4 opened.
Apr 12, 2009 | Generac Guardian 100 Amp Transfer Switch...
Tools & Hardware - Others Logo
96 people viewed this question
Top Dayton Tools & Hardware - Others Experts
Craig Butler
Craig Butler
Bill Boyd
Clive
Clive
Are you a Dayton Tool and Hardware - Other Expert? Answer questions, earn points and help others
