Question about Health & Beauty
I need a manual for energym turbo charger. I can't find it anywhere.
Er 1, que es ????
Posted on Nov 21, 2013
I bought a T/3 T4 T3 turbo charger 2.25" 4 bolt exhaust .48at turbo Charger 42ar oil cooled only for an 04 maxima and I'm wondering what accessories am I gonna need piping and intercooler wise and turbo...
Turbo manifold, blow off valve, waste gate, intercooler, turbo timer, piggyback or standalone ECU, most likely an all new exhaust system, new intake, filter. An oil cooler may be needed, as those turbo chargers are most likely cooled and lubricated by the oil in the engine, needing to be piped through the turbo itself.
Jan 11, 2018 | 2004 Nissan Maxima
Nissan elgrand e50
fit a turbo charger to it . Need a turbo charger --a manifold for the turbo charger and an up graded chip in the CPU to get it all running properly and a lot of dollars
Jan 07, 2014 | Cars & Trucks
Elantra 2004(Diesel, done 136,000km) Leak in Turbo Charger
A turbocharger can leak. Some of the gaskets might be shot and need to be replaced or a hose might need to be replaced. If the turbocharger itself is leaking and not a gasket then the turbo housing is probably cracked. If you get the turbocharger replaced it should last a good 20 years or so. The only thing that usually wears out on turbochargers are gaskets and thrust bearings.
Mar 24, 2012 | 2004 Hyundai Elantra
My 04 VW Jetta blew thick white smoke from tailpipe after freeway drive. No indicator lights came on, all oil leaked out (after smoke started)... is this engine or could it be just the turbos? Right...
A new turbo charger is about $340, but you can buy the bearings and seals and rebuilt if yourself for about $100
http://turbosandparts.com/
It is not hard, and it does not take long to do.
I normally do not bother with synthetic, but with a turbo charger, it might be worth it. What really seems to ruin turbo chargers the most is not letting them cool off before parking.
Once you turn off the engine, there is no longer any cooling, so the build up heat will burn up the oil and seals.
Run the engine for at least 5 minutes below turbo levels, before shutting down the engine.
Sep 06, 2010 | 2004 Volkswagen Jetta
My toyota 3C turbo diesel engine the turbo compressor is flooding of oil . I can.t trace where it is coming from That is why I am searching service manual for this turbo charger. 12ct
If your turbo housing is getting flooded with oil the it can only come from the shaft seal on the inside of the turbo.
You will need to remove it and replace the shaft seal.
Jun 19, 2010 | Cars & Trucks
CHANGING GOLF TURBO
Go to your public library. They have repair manuals for most procedures and cars. GOOD LUCK THAT IS A BEAR OF A JOB TO REPLACE THE TURBO .
Dec 30, 2009 | 2001 Volkswagen Golf
Whats the make-up of the r?otating assembly
It all depends on how much pressure you intend to run the turbo or supercharger at. If you won't exceed around 12 psi, you can keep the engine stock without damaging or shortening the engine life too much. If you wanna go bigger than that, you might need to upgrade the pistons and crank. And as for compression, either a charger or turbo will do the same thing as far as the compression is concerned, so if compression is too high for a turbo, it's too high for a charger also. And I'd start checking more for upgrading the fuel system than the engine assembly parts, cause you will need more fuel in the engine to compensate for more air coming in due to turbo or charger way before you need to strengthen the engine for the extra power.
Jul 08, 2009 | 1999 Ford Mustang Cobra
Turbo charger over boost was diagnostic term. Also noticed sort of a tapping or clicking off and on at speeds of over 60 mph after having problem with turbo
variable vains are sticking in the turbo,you can try moving the lever manually to clean them or using a good quality fuel cleaner,if this fails yiu will need a new turbo
Jan 30, 2009 | Volkswagen Golf Cars & Trucks
MX-6
Have you tried http://alldatadiy.com/. They will sell you a 1 year subscription for under 30.00.
Jun 15, 2008 | 1989 Mazda MX-6
Health & Beauty Logo
1,443 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
