Question about Ricoh AC205 All-In-One Laser Printer
We had a paper jam Ricoh AC205, clered it but now says scanner locked and won't print
  • 590 Answers
The scanner lock is not due to paper jam.. There is a dedicated knob provided for lock /Unlock the scanner.
To unlock the scanner,
1)Gently pull the scan lock label until it comes away from the machine. This will pull the scanner locking switch into the FORWARD (Unlocked) position automatically.
After Unlocking press Clear/Stop Button.
I hope this solves your problem.
Thanks
Posted on Feb 14, 2010
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
Ricoh 3245c paper jamming in fuser any help please
Check to see if;
1. the exit sensor in working properly
2. There is a piece of paper stuck inside blocking the paper path
3. Hot roller strippers are in good condition.
Nov 24, 2011 | Ricoh Office Equipment & Supplies
I NEED A DRIVER FOR RICOH AFICIO FX 200L (PRINTER/SCANNER/FAX)
Hi there!
You can download the driver for Ricoh Aficio FX200L from this website: http://support.ricoh.com/bb/html/dr_ut_e/re/model/ac205/ac205en.htm
Just choose your Operating System and it will scroll to the list of driver that is compatible with your computer.
Hope this helps!
Apr 09, 2011 | Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
I tried to print a document from my computer and the printer says( No paper) Add paper. The tray is full. It then says PC Print Pending. Can you tell me what to do to clear this problem. I have a AC205..
Your problem may be a simple as paper dust.
Take all the covers off get a can of canned air and blow out everywhere you can reach especially in the areas where there are or my be sensors. Be careful not to spay to much in one place or you'll end up with condensation and then condensation problems.
Jun 14, 2010 | Ricoh AC205 All-In-One Laser Printer
Cant install ac205 with usb and i dont have a disk
Donload printer river here, postscript driver and printer switcher here:
http://www.ricoh-usa.com/solutions/common/universalprintdriver/default.asp
Dec 23, 2009 | Ricoh AC205 All-In-One Laser Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Faxes stuck in memory
The only reason they shouldn't print is due to a technical problem. There are no error messages or red lights at all?? That's very strange.
It must be a software glitch of some sort. You can do a memory clear to empty it out and perhaps restore the proper functioning, but it does set the machine right back to factory defaults, so you will have some settings to restore afterward.
You can get the manual here if you don't have it. Memory reset procedure is on page 8.2:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/ac205/ac205en.htm
Mar 04, 2009 | Ricoh AC205 All-In-One Laser Printer
Savin AC205
In the print output tray there is a green lever that locks the scan bed in place. Move this lever and the problem should be resolved.
Dec 26, 2008 | Ricoh AC205 All-In-One Laser Printer
Ricoh AC205 All-In-One Laser Printer Logo
135 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
