Question about Ricoh AC205 All-In-One Laser Printer
Paper jam- now says"scanner locked" help!!
We had a paper jam- cleared it but now it says "scanner locked" and won't print- help please
    Brigadier General:
  • 3,917 Answers
In order to exit this error checks out for a blue latch in this section. Pull it towards you. It does take a little pressure to pull. You may need to press cancel a few times. That should clear it out. If it doesn't, the scanning unit assembly needs replaced.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 06, 2010
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Can't clear 01 fuser jam
open top scanner, open inner cover where printed paper normally comes out. push left and right locks on the fuser and the fuser will come out. remove jammed paper. put back together in revers order. paper jamming in the fuser is a sign the fuser is faulty/worn o non genuine toner is being used.
Feb 08, 2011 | Samsung CLX6220FX COLMON MFC Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Please advise what you charge for solving following problem:\r\n"Paper jam on Brother MFC-260C:Following Brother User's Guide, I removed the Jam Clear Cover, and pulled out jammed paper, but got only...
1. Unplug machines power cord from the power outlet. 2. Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position. 4c89ecbe03c0173ae1000000cd8620c6.gif 3. Remove all of the paper scraps stuck inside the machine. NOTE: The print head can be moved manually with hand to assist with removing all of the paper scraps. 4c89ed1103c0173ae1000000cd8620c6.gif
4. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper. Then close the Jam Clear Cover (1).
5. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
6. Remove the paper tray from the machine.
7. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
8. Using your hand, lift the front of the machine approximately 6 inches off the surface.
9. Look inside the tray areas roof of the machine and you should see a row of black rollers. See picture below.
10. Look in-between each of the black rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
11. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
12. Place the machine gently down onto the surface.
- If paper scraps were found and removed from the machine, continue to STEP 13.
- If no paper scraps were found inside the machine, the paper in the tray may be causing the issue. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper must be replaced.
- If you do not have replacement paper, follow the rest of this solution, after you have replaced the paper.
- If you replaced the paper, continue to STEP 13.
13. Put the paper tray back into the machine.
Dec 18, 2010 | Brother Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
If your scanner stops scanning due to a paper jam in the Automatic
Document Feeder, a warning dialog box opens after a few
moments.
To clear a paper jam:
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
2. Remove the jammed paper and close the cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Ricoh AC205 All-In-One Laser Printer Logo
54 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
