Trying to get DVD recorder to work with HDTV. Recorder is Panasonic DMR-EA18; TV is Panasonic, Class 720p LCD HDTV. Both have viera link. Following hook up instructions in manual using red, white and yellow AV cables, and tuning the comcast box to the station that I wanted to schedual a recording, apparently worked, but when I tried to play it back I got this message: Your HDTV does not support AV cables. Use YPR Component cables. - So I got the component cable and connected it to TV and recorder - NOTHING. Could not schedual or play back presumably. Then I connected the comcast box to the recorder with the origonal triplet red, white and yellow leaving the component connection between recorder and TV in place. Then I could program a schedualed recording bu when I tried to play it, I got this message: Your HDTV does not support HDCP. Use YPR Component to wath TV. What I need is instructions of what cables to use and whether they go "out" or "in"- I'm rather familiar by now with the recepticles on the STB, TV and recorder. Thank you/
  • 10 more comments
  • twandx Feb 06, 2010
    The Comcast STB has only one set of component and one set of AV recepticles.
    But I do not have the red and yellow cables anyway.
    The manual claims that the connection can be made using an HDMI cable from recorder to TV but that does not function at all.
    As I wrote before - The Comcast STB has only one set of component and one set of AV recepticles.
    There is no place to connect the two headed cable on the STB.
    I cannot try the Rylee Smith solution because
    the Comcast STB has only one set of component and one set of AV recepticles.
    There is no place to plug in the two headed unit he suggests.
  • twandx Feb 07, 2010
    cableguy 3028 -
    Thank you. Worked great but NO SOUND. Can you address this problem?
    Cableguy 3028
    Follow up from my previous post -
    I did another test run and got this all too familiar message: "DVI Alert - HDTV does not support HDCP. Use YPPb component connection to watch TV"
    Again, there was no sound - also no picture this time - just the big green alert.
    There are white and red recepticles on the TV located as you describe but nothing similar on the recorder. All that is left there unused is the red, white and yellow recepticles - "out".
    It did get the sound going on two tests I made - I thought everything worked, then that DVI Alert came on for the tests I made afterwards.
    Once that Alert sign comes on, nothing works. There is no sound or recording - just a big green sign which I have no way of removing.
  • twandx Feb 08, 2010
    Whether I used the recorder remote or the TV remote [you did not specify], I do not get any user preference menu. The closest I came to what you suggest is from the recorder remote setup - with this screen:
    COMPONENT OUTPUT SCHEDULE
    480i
    480p
    720p
    1080i
    But only 480i and 480p are active. Presently set on 480p.
    I cannot find a way to activate the 720p.
    please indicate the model of your Panasonic TV
    IT IS IN THE FIRST LINE OF MY PROBLEM REPORT ABOVE.
    and try having a media ( not the one you have recorded ) played on the
    WHAT DO YOU MEAN BY MEDIA? A DISK?
    recorder connected to the TV
    using RCA ( 3 ) cables, and see if playback works.
    ARE YOU TALKING THE COMPANY RCA? COMPONENT OR RED WHITE AND YELLOW?
    You asked -
    Feb 08, 2010
    - Do you have anything connected to the TV via HDMI or DVI??
    The answer is NO.
    Thanks, I'll try again.
    You asked:
    Feb 08, 2010
    - Also are you trying to record HD channels or is this on any channel when you record it.
    Have NOT tried to record any HD channels.
    Feb 08, 2010
    - Sorry about that use the cable box remote and turn off the cable box and then press the menu button for the cable box.
    Nothing happens. The TV is unresponsive to the cable box remote. When I use the TV remote, it does respond with a menu but it is not helpful.
    The closest remote that comes with the info is with the recorder which gives 4 component output scheduals 480i or p. 720p is listed but not active - will not change. Other inactive is 1080i.
  • 5,807 Answers
Please indicate the model of your Panasonic TV
Posted on Feb 08, 2010
  • 6 more comments
  • Rommel Cana
    Rommel Cana Feb 08, 2010
    please indicate the model of your TV
  • Rommel Cana
    "The Comcast STB has only one set of component and one set of AV recepticles. " use these cables
    temporarily just for " eliminating the cause.".
    You mention " Class 720p LCD HDTV " and the player output is 480p ( which can be adjusted ? )
    Try the 3 RCA cables first , use any media , such as disk ( any media known OK that have
    previously work ) , or try using your HDMI cable,
    Just like to know if playback is possible on both
  • Rommel Cana
    RCA cable = " red " , " white" , and " yellow " component cable
  • Rommel Cana
    Panasonic LCD TV model starts with/ like TX-L32G10B
    Plasma Model starts with TH-42PX75U
  • Rommel Cana
    and these is for the HDMI cable
  • Rommel Cana
    a ) what i am trying to say is:
    for playback first
    have a media , a DVD or anything just to see on your TV if the " Recorder " is working OK.
    we will go to your recording process , after we establish that you can play clearly ( good audio and
    picture ) on your TV and note down the settings.
    Note: the other one is not yet connected ( comcast box )
    or try connecting Comcast direct first on your TV without the Recorder
  • Rommel Cana
    that partially answers your problem.
    Have the Comcast directly connected to your TV , if you can work these out then recording will follow.
    Post the settings and will try to work these out.
    Note : disconnect Recorder ( should not be connected ), will connect it later
  • Rommel Cana
    post also the model of your Comcast STB
  • 176 Answers
Try this option....
  1. Connect with the Yellow/Red/White cable from the back of the cable box to the input on the back of the the DVD.
  2. Connect the component cable to the component out of the DVD to the Component in on the TV.
  3. Go to the SETUP menu on the DVD player.
  4. Select TV SCREEN.
  5. Select COMPONENT OUTPUT SIGNAL.
  6. Select 720p and press OK.
**** NOTE: If you can not view the menu screens then press and hold the STOP and PLAY buttons down at the same time for 10 seconds to reset the video output setting to view the menu****
When to go to record this what you need to do.
1) Set the cable box to the channel to record.
2) When you set the DVD to record tune the DVD to IN1 as the recording source by pressing the input button on the DVD remote.
This should get you working...
Good Luck....
Posted on Feb 07, 2010
  • 3 more comments
  • Robert Feb 07, 2010
    When you connect with the component cable you need the Green, Blue and Red video but you also need to connect to the White and Red audio out just to the right of the component connection on the recorder in order to get sound.
    that is correct... use the red and white of those and leave the yellow one open this will provide the sound from the recorder to the TV.
  • Robert Feb 08, 2010
    Also try this on the cable box...
    1) Turn the power off on the cable box and then press menu. This should bring up a user settings menu.
    There should be an output option make sure it is set to 720 and then there should be a setting for YPbR override and this should be set to 480i.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check this picture on how to link your LCD HDTV with Comcast Box and DVD Recorder: Trying to get DVD recorder - b9f474b.jpg
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • Rylee Smith
    Rylee Smith Feb 06, 2010
    The only way for it to work perfectly fine is shown in the picture so you can try to get the cables and attach them. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
I am trying to connect my DMR E55 DVD recorder to my Viera 32LX TV and take the satellite signal from the TV and the recorder is reading nothing. I am using optical cable and a SCART. What am I doing...
To hook up you need to go from the satellite box to the recorder then to the TV. If you do that then you should be able to record the show on Tv. You can get the manual on the link below. Page 7 tells you how to hook up.
http://www.hollywoodstudiorentals.com/uploads/030708__Panasonic_-_DMR-E55%5B1%5D.pdf
Dec 30, 2009 | Panasonic DMR-E55 DVD Recorder
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Jan 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Hdmi connection
you need to connect to your tv via scart untill you have been into the setup and enabled hdmi
Dec 29, 2007 | Panasonic DMR-E80H DVD Recorder
Open Questions:
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
