Question about Dryers
My Lakewood 792/JR space heater simply stopped working...
My Lakewood 792/JR simply stopped working. I opened it up, cleaned out most of the accumulated fuzz, and used the multimeter to find out how far juice was getting - where it stopped. I found that juice is not getting across a 'resistor' sort of device that jumps across two of the heater coil spacer legs. I need to know what this device really is, its value, and where I might find a replacement. I will solder it in place myself - that will probably fix the problem. Thanks!
  • conbrio56 Feb 06, 2010
    I have found this issue on another online forum. The device is an inline fuse and the value printed on the side appears to be 121C (250F),if this helps..... htx
  • conbrio56 Feb 07, 2010
    The part is a Microtemp brand thermal fuse, series G4 121˚C.
    Does anyone know where I can get this part?
    thx
SOURCE: Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Posted on Apr 22, 2007
konzzz
  • 255 Answers
SOURCE: need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
karns
  • 122 Answers
SOURCE: we have a "Nutone"- ceiling
You might be able. check Ebay. but it being as old as it is, you may not be able to find parts anymore.
Posted on Aug 13, 2010
SOURCE: Where can I get a replacement thermostat for a
I found one at this place, but is half or more price than the whole heater with shipping.
http://www.allpartsinc.com/productdesc.aspx?code=104458-01
part #
104458-01 - THERMOSTAT, BI-METAL 2 WIRE
Posted on Oct 25, 2011
timobrien15
SOURCE: Hello, I have a Lakewood space heater, Model #
The heater is equipped with a thermal fuse. Replace that and it will work like new.
Posted on Nov 16, 2014
The switch 750/1500 watt doesn't work
Replace it with any rated double throw double pole switch. Continuity check the switch first, to be sure it's the switch that's the problem.
Dec 11, 2013 | Lakewood 792/JR Utility Heater
Lakewood Model 792/A My heater has stopped working. The light indicates that it is receiving power. I checked the tip switch to see if stuck open. OK Next step please? Jeff
Separate the case and trace out the wiring you are looking for an over heat limit switch. These are usually at the top of the case. You should also go over the element with a volt ohm meter make sure it is good, once you locate the thermal overload check it with the volt ohm meter it should read closed or dead short. If it reads open here is your culprit. It has been my observation that replacement parts can generally cost as much as replacing the entire heater. These I can pick up all day long for $19.00 at Home Depot the call them milk house heaters. Good luck with the repair.
Dec 28, 2010 | Lakewood 792/JR Utility Heater
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Hello, I have a Lakewood space heater, Model # 792/JR, and one of my kids tried to dry her shirt by placing it over the heater and now it comes on but doesnt heat up. Can this be fixed?
The heater "over-heated". It's supposed to have a safety cut-out. The question is, can it reset itself? If there is no manual reset button on it, leave it unplugged for 30 minutes or so. If it still doesn't work, spend $20 on a new one.
Jan 19, 2010 | Lakewood Engineering&Manufacturing PHT150...
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Dryers Logo
251 people viewed this question
Top Dryers Experts
