Question about RCA RS2041 CD Shelf System
CD door will not open
Door will not open, CD will not eject
  • 5 more comments
  • Anonymous Mar 14, 2008
    dvd drive eject button do not function on toshiba satelite
  • Anonymous Apr 16, 2008
    mY CD door will not work... Their is a functioning music cd that works inside. The eject botton and the button near the door does not open the door. The CD seems to function in all other ways.
  • Maggyta May 05, 2008
    The cd drive will not open, appearing on screen open, then close, and finally error, how can i fix this
  • Anonymous Jun 04, 2008
    cd will not open
  • rogueleader Mar 08, 2009
    Our rs2041 CD door will not open, either. I took it apart and there is a belt under a large gear that is loose and appears to be the problem. I am going to look for a generic belt to solve this. This may sound crazy but I may try a rubber band such as for hair. I will keep you posted.
  • Fletcher Wilson
    Fletcher Wilson Oct 26, 2012
    First is the light coming on when you push the botton if it is find a paper clip strighten it out push the bottonand below the door on the drive you;ll see a small hole push the paper clip into the hole you will fell slight resitance push if it gos in it should open the dor try to do the bothe about the same time this will put it back in time but warning your belts are slipping so a new drive is down the road you can also try the eject botton on the computer if sa **** is inside
  • Fletcher Wilson
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    President:
  • 624 Answers
This is normally a problem with the belts or gears that are part of the loading mechanism. sometimes the gears get out of timing.
Whatever is causing the problem, there is no easy fix that is designed for the end user to perform besides unplugging the unit for about half an hour, this resets the micro and it may or may not help.
I work at an authorized RCA repair center and I am sorry to inform you that RCA does not supply parts for any of their audio equipment any longer.
If it is under warranty you can get an exchange from the retailer you purchased it from or send it directly to RCA. You can contact them and/or download user manuals at this website:
http://support.rcaaudiovideo.com/
If it is not under the warranty it is very unlikely that it can be fixed.
RCA does not seem to care about the customers of theirs unless it is within warranty coverage.
If this information is of any help for you, please leave me a good rating or reply back if you need any more help. I am always willing to offer assistance.
Posted on Jun 20, 2008
Indeed, it is almost certainly a problem with a tired belt, and indeed, repairing the problem is suitable only for a qualified professional (and therefore not cost-effective). However, if you have a lot of patience, and you're inclined to remove a bunch of electrical connectors and screws (and keep track of where they belong), I'm hoping to find a source for generic replacement belt(s) for this unit, and will keep you posted...
Posted on Dec 14, 2008
    Problem Solver:
  • 9 Answers
I put in a combo DVD/CD-Rom drive a while ago and have had problems with the door not always opening...I fixed it: contr panel>system>hardware>dev mgr> +DVD/CD-ROM drives>lite-on combo SOHC...>dbl click on it>properties>then uncheck the box "enable degital CD audo for this CD-ROM drive">OK>x out and finish with okay for system properties. My drive now works everytime.
Posted on Aug 05, 2010
How can I eject a cd drive from an Acer Aspire e 15?
Are you asking about ejecting the drive or the CD in the drive? The drive you may or may not be able to eject. Flip over the laptop look for slides or what looks like switches under the CD. Some units may have these releases. You usually slide them to one side or another and the drive can be removed.
If you are asking about the CD, i.e.the laptop wont power up but you still have a CD/DVD in the drive you want. Usually there is a tiny hole on the drive door. It's about the same size as a paperclip diameter. Unbend the paperclip until you have about 1 inch of wire straight out at a 90 degree angle from the clip. Gently slide the wire into the hole on the drive door and give it a gentle push. The door should unlock and come open just a bit allowing you to pull the door all the way open and remove your captured CD. The gears that open and close CD's are plastic and can be stripped very easy so be gentle. Close the CD by slowly pushing the door closed.
Dec 31, 2014 | Acer Aspire Computers & Internet
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
I have a deskstop computer by Acer model AX5900. I am trying to eject a disk but it is stuck and won't eject. Help! What do I do? Thanks
eject cd drive door manually
there are small hole at the cd door, use small thing like paper clip that can in to the hole, push at the hole until the door open, if the door was open you can take thi deisk inside
i hope this helpful
thank you for using fixya
Feb 07, 2011 | Acer Computers & Internet
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Cd door will not open
same thing happened to me. turn the system off, unplug it. then back on and after you switch to CD mode (for some reason the CD tray will not eject unless in CD mode), once the system tries to lock on to a specific CD tray, hold the eject button down for 5 seconds. that worked for me. may have been dumb luck but can't hurt.
Aug 27, 2008 | Venturer CD2770 CD Shelf System
Front door won't open
open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
Feb 03, 2008 | Technics SL-MC700 110-Disc CD Changer
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
RCA RS2041 CD Shelf System Logo
956 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
