Question about Uniden Cordless Phone
IDECT cordless phone, on small round base
This has stopped ringing when someone calls my number. I do not knw if it has a mute setting, and have mislaid my handbook
  • Anonymous Apr 05, 2008
    Ringtone on my Idect phone does not work when plugged through my/ Orange Livebox and not directly through the BT line.Any suggestions
I have verge 500 twin, the handset just stopped responding to the base and i have not found the manual to check trobleshooting.
Posted on Jul 07, 2009
My keypad is locked by my 1 yr old cant unlock it
Posted on Sep 14, 2009
Hello.
My IDECT corless phone is saying "keypad locked" I have not seen this before in 2 years of having the phone. How can unlock this please?
Posted on Jan 28, 2009
I have three e1100 two of them have become locked...don't know how and don't why but they have become totally useless,I have one left can you please tell me how to unlock the other two? Thankyoui
Posted on Sep 24, 2012
Hi my cordless phone froze when someone tried to call me. How do i unfreeze it?
Pull the battery out and let it set for 3 min. This is assuming it is battery operated....
Mar 23, 2016 | Idect Solo Vintage Styled DECT Cordless...
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
I have a idect c5i. i am unable to take calls when i receive a call. the phone keeps ringing and on pressing the call button, i get that the handset has accepted the call but i do not hear the sound of...
Check the handset is registered to the base- if your handset has been assigned a number it has. Can you call out from the phone? If you can I would advise disconnecting from the power and telephone line for 10-15 mins and removing the batteries from the handset and pressing every key (press them all individually in any order) the reconnect and see if you have the same problem, if you do and the item is under 30 days old return to the store with your receipt, if not and was purchased from Argos go to the store with receipt and they will send to Idect for repair, if purchased somewhere else contact 0845 3459677 and they will repair the phone under the guarantee providing you have the receipt.
Mar 05, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Change the number of rings on my phone before answering machine comes on?
Press the MENU button repeatedly until "Change number of rings" is announced. Press the CHANGE button until the number of rings you want is announced. Press the MENU button to save the setting and go to the next feature or press the PLAY/STOP button to save the setting and exit programming. The PLAY/STOP button is the round button in the lower right of the base unit with the REPEAT/SLOW and SKIP/FAST buttons surrounding it. Here is a link to download the manual.
http://att.vtp-media.com/ecp/documents/product_Product/713/UserManual/2188/e5630_manual_bkm.pdf
Feb 06, 2011 | AT&T E5630 Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
NO CALLER ID 25881EE3-A
The GE Cordless Phonemag-glass_10x10.gif brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems.
    Before You Start
  1. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  2. Phone Setup
  3. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  4. The Basics
  5. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | Uniden Cordless Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Idect x1 cordless phone
i have the same issue but cant find any info on it
Jan 16, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
735 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
