Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer does not print when turned on it makes a
Printer does not print when turned on. It makes a continuous clicking sound. An error message on front of printer said cartridge jammed, unjam. Also I think there is enough ink in the cartridges however not sure, but no error message comes up for low ink. Need assistance!
Thanks
  • 163 Answers
Try dis-connecting all of the cables from the printer, then re-connect them back.
Posted on Feb 06, 2010
The printer shows the error message "Turn power off and then on" but it does not get off swicted off and it continues to blick the same error message,how do I fix it?
Sounds like a lack of communication from your printer to your print port.
Try this... left click your task bar in lower bottom right corner. if you see a small icon that looks like a printer open it. Then left click it and select discontinue/cancel print job. With the printer still on restart your computer,( save all work before you do the reboot.)
This should bring your printer back up to communicating with your computer.
Hope you good luck.
Jul 03, 2015 | Office Equipment & Supplies
I am getting an error of: 49.4Co2 on my HP color laserJet 5550hdn. Have tied turning it off; unplugging butno luck. the error message continues to appear
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application.
If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all
cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer.
Aug 29, 2011 | HP Color LaserJet 5550hdn Printer
49.c02 Error To continue turn off then on HP4700 LaserJet Color Printer
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79
Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
displays only with a certain software
program or print job, contact the
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
Aug 08, 2011 | HP LaserJet 4700 Printer
Error code 490665 van HP Laserjet 2420
49.XXXXX ERROR
alternates with
A critical firmware error has occurred.
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
different software program. If
first program and try printing a
software program or print job,
for assistance.
If the message persists, try this:
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
4. Remove all of the
5. Turn the printer on.
6. If the error message
disappears, reinstall
individually, making sure to
turn the printer off and then
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
10. Replace the formatter
Jul 11, 2011 | HP LaserJet 2420 Printer
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Turn on printer and light continues to flash. Not
What the flashing light means
The Power light can flash for several reasons:
• The printer cover is open.
• The printer is out of paper.
• A problem exists with the printer, such as a paper jam or a problem with a print cartridge.
If an error message appears
Read the error message that explains the problem and its solution.
If no error message appears
Check the status of the printer by using the printer tools. To gain access to the tools, open the Printer Properties dialog box, click the Services tab, and then click the Service this device button.
Use the printer tools to perform the following tasks:
• View estimated ink levels.
• Clean the print cartridges.
• Calibrate the printer.
• Print a test page.
• Perform other functions as needed.
Jul 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Lexmark x83 error message
there is no communication between my printer and the software.i can scan,but i can not print.
Aug 30, 2008 | Lexmark X83 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
