Question about Culligan Sediment Water Filter
How do I clean back flow filter on water softner
I need details on how to clean the back flow filter on my water softner.
    President:
  • 2,030 Answers
You dont..you just replace it.
Posted on Feb 06, 2010
Filter light goes on stays on and dryer will not go Our dryer stopped and we cleaned out the filter front and back remoed the hose abd vacuumed it all out it still flashes filter and will not start
Try to clean your filter this way...use dish washer soap and hot water to clean your wire mesh air filter...Fabric Softner Sheet deposit a invisible film on the wire mesh filter and blocks air flow. This is a frequent problem not everyone is aware of.
If this answer your question and you have done a good cleaning of your filter I am happy to help you. Continue the drill at every filter lint removal.
Aug 20, 2017 | Dryers
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
The softner is no longer been pulled into cycle. We have cleaned the pwder/softner compartment and also followed the service instructions, removed the filter and cleaning that, but the softner is still in...
Mine did this when the filters in the hoses were clogged and it was taking too long for the water to enter the machine. I cleaned the filters and the softener was pulled into the cycle. Hope this helps.
Jun 20, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it...
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
Nov 29, 2010 | General Electric GE SmartWater Household...
Low pressure through water filter
Your filter got clogged. Sometimes when the water levels start to get low, you start getting harder water even if you have a softner so you will start getting filters clogged more and more. This is fairly common like I said when the water system for your state or county start to get low.
Jun 08, 2010 | Whirlpool GS5SHAXN Side by Side...
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
Samsung frontloading washer won't dispense fabric softner
clean filters in washer inlets on back of washer. take off hoses and look up inside of inlet, pull out the filters by pulling stright out on them. then fush backwards to get sand or whatever out of fiter
Dec 30, 2008 | Samsung WF337AA Front Load Washer
Erroe code F H
jse, most of the time when I run into this problem it's because of the flow meter. This is a reed device that sits in line with the water inlet valve and monitors the water coming into the machine. Things to check; make sure both water valves are on and that the inlet valve screens are clean. (You get to them by removing the hoses to the washer). The drain pump filter is clean. (Remove the bottom panel and unscrew the pump filter and clean out). The inlet valves are actually working. That the drain hose is not too far down the standpipe causing a siphon. All the harness connecting to the inlet valves, pressure switch, drain pump, flow meter and main control are seated properly. You will have to remove the top to get a look at these. Three screws on the top backside and it slides of toward the back. If all these things check out. Then I would suspect the flow meter itself. Easy job. Catriver..
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Culligan Sediment Water Filter Logo
259 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
