Question about Addtron (AEF-1004) Networking Hub
Addtron AEF-1004 network hub faulty?
HI,
An Addtron AEF-1004 network hub has landed on my desk. When powered up, the LEDs indicate power on, collisions occuring, ports 1 and 2 connected to kit (when nothing is plugged into them) and activity on port 4, activity that isn't happening. Is there a way to reset this box, or is it - to use the term correctly, buggered?
cheers
PB
Hey Beastman,
You have a real beast screwing around in that hub. You have choises:
1. Call the animal control department :)
2. Shoot it with a 22 :):)
3. Get another one.
A Hub acting like that has got its marbles juggled. Switching it on and off is the only way of flashing, and if that doesn't work, its jinxed. If you network it, you could spend a lot of time fixing network problems.
Hubs are cheap and not worth the headache.
Good luck.
Posted on Feb 27, 2008
Need driver for Addtron AEF-330TX-1
Hello this is the only driver site i can find:
http://list.driverguide.com/list/company34/index.html
You maybe have to login as a user to download the file.
Or you can buy a new addin card that supports your
windows system.
Make sure the driver is to find.
Good luck
Oct 25, 2012 | Addtron AEF 330TX (AEF-330TX-20P) Network...
Power outage in our area - everything stone cold for hours - when power came back on procurve 2524 all LEDs on and orange Fault light on steady - no cli or web communications - - is it dead?
Please try to power off the switch and wait for 2 minutes and power ON.
If you still not getting the console access to the switch then please go back to the vendor if your product is still under the warrenty.
As per your description ( All LEDs ON , No Console and No Web) indicates to switch didnt pass the POST and it is laying there, trying to recover.
Dec 05, 2010 | HP Computers & Internet
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
I had an idea to use a working addtron 16 port hub as a cheap and simple way to allow our boys access to the net and have control of their time online as well :>) We have a verizon account with an...
You do what you are describing, attach the hub to the router in any regular lan port. Then just plug everything you need to into the hub. Make sure dhcp is on on the router (it probably is) and just set it to automatically obtain the IP on the computers attached. The router can go through the hub (or switch) to give them IPs.
Aug 12, 2009 | Addtron (ADH-0016) Networking Hub
How to check whether its working or not working?
If your PC LAN Card is active just connect the switch with Straight cable - & --you will see one yellow box in ritht side corner down to monitor screen...where the time appears.....also you can check in the Network Connections Folder. Or Right Click My Network Places> Properties> You will see local area Network....> Connected...then it is working if disconnected it's not working....Good Luck
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
HOW TO CONNECT IT TI A COMPUTER?
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc
My network switch LEDs all blinking even without LAN connected
The LEDS blinking normally would indicate reset internally or when the unit has just been powered on. Continous LEDs lighting up or flashing with or without a connection is an indication of extensive hardware failure. This could have been brought about by a near lightning strike, a power surge or simply component failure. Unfortunately the repairs is not economically reasonable and therefore a replacement might be better off. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Cnet PowerFAST Networking Hub
Problems with Addtron AES820TX Hub
Is there any change in the configuration made, like is ICMP blocked. If youa re bale to pass traffic without any issues and if the issue is just that you are not able to ping the HUB there is a posibility of blocking the ICMP requests.
Dec 27, 2006 | Addtron Workgroup Networking Hub
Addtron AE-200 network card - jumpers setting
hi check this out: http://groups.google.com/groups/search?hl=iw&q=Addtron+AE+200+jumper++settings&qt_s=%D7%97%D7%99%D7%A4%D7%95%D7%A9 good luck
Apr 25, 2006 | Addtron AE 200 Network Adapter
Computers & Internet Logo
165 people viewed this question
Top Addtron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Addtron Computer and Internet Expert? Answer questions, earn points and help others
