Question about i-mate SP5m Smartphone
My imate 9502 sound suddenly stopped working about a month ago. The sound stopped working in both internal and external speakers. When people call me they can hear me but i cant hear them.
    President:
  • i-mate Master
  • 1,118 Answers
I had experienced such a problem a long time ago, and, as far as I remember, it was related to the installation of Voip softphones, such as fring, Nimbuzz, agephone, etc. The 9502 doesn't seem to like them, at all. All sound channels simply got muted, normally after the device was suspended after a Voip call. A simple soft reset (by pressing the reset pin on the keyboard with the stylus pen) used to solve the problem.
However, if a soft reset doesn't help in your case, you'll have to hard reset your device. If its keyboard and screen are fully operational,.it is recommended to backup your personal data first (PPCPimBackup is an excellent and small application to do it), since a hard reset will restore your device to its factory defaults. Then, tap on 'Start > Settings > System tab > Master Clear' and follow the instructions.
If your device is not operational, at all, please, post here, so I could tell you how to hard reset by hardware means.
Good luck! Carlos
Posted on Apr 08, 2010
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Imate 9502 daylight saving time reset. How can I stop my imate 9502 phone from reverting back to Australian EST although DST ended on 3 Oct?
Go to 'Start > Settings > System tab > Clock & Alarms > Time tab', and make sure the 'Sync to current time zone' checkbox is unchecked. Press 'OK' a couple of time to leave the settings pages.
This way, you'll have to manually set your correct time when a DST time changes.
Hope it works for you.
Anyway, please, let me know I can assist you any further.
Regards,Carlos
Nov 04, 2011 | i-mate Ultimate 9502 Cell Phone
I have a SONY VAIO VGB-140E. Using the external speakers, the sound is working. The internal speakers sound is suddenly stop working. I did re-install the sound drive and also did a system restore but no...
go into your sound driver options and locate the speakers you are trying to use, weather it be external or otherwise. Make sure the volume is up (i know obvious but still)
rate yea?
Jul 08, 2011 | Sony VAIO VGN-NS140E/S Notebook PC
My laptop is year and half old and couple of days back suddenly my laptop's speakers stopped working . i tried all option in the laptop to fix it .its not working.please help.
Steps to be followed:
1. check whether audio driver is installed properly ? if not install audio driver & check
2. check audio setting in control panel & confirm
3. connect external speaker in laptop and check whether sound is coming? if sound is coming then ur laptop internal speaker need replacement
4. if there is no sound in external speaker then need to check ur motherboard or sound card.
All the best.
Aug 16, 2010 | Computers & Internet
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
MacBook Sound Driver Issues
Sounds like the cutout switch in the output jack is stuck open, it is a techy fix sorry (at least it is not a board failure)
Jun 02, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Imate 9502 Sound Problem
New report: the problem was not caused by HTC Home, after all. It was fring's fault. In fact, I think the 9502 doesn't like VoIP client applications at all, because I have just experienced the same problem (all sounds desappearing from all possible channels, including BT) when trying the age client. So, my advice is: uninstall all VoIP client applications from your device !
I'm now in process of try & error in making the native WM6 VoIP feature work through 3g (since via WiFi it is already working: probably a codec issue)...
Cheers!
Carlos
Dec 29, 2008 | i-mate SP5m Smartphone
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
i-mate SP5m Smartphone Logo
112 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Bilal Ahmed Qureshi
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
