Hi. I bought a Samsung SCX-4826FN two wks. ago. When I fax (or make copies) using the feeder at the top, I get multiple black lines running top to bottom on the faxed or regular copies. What's going on? Thanks.
Try to clean the OPC drum on the toner with a soft cloth. Wipe the ITB belt as well and reboot the machine.
Posted on Feb 22, 2010
  • 79 Answers
Check ur machine drum catridge, maybe it getting damage or some dust is blocking in drum unit.
Posted on Feb 09, 2010
Error message
low heat does not allows u to print , wrong error
May 07, 2014 | Samsung SCX4826FN AllInOne Laser Printer
Thick black lines when scanning Samsung SCX-4824FN
The contact image scanner is faulty or the cable from the motherboard to the contact image scanner is faulty. I would bet it is the CIS as this scanner is used in many different machines (canon,lexmark,sagem) and it gives problems in all the machines. You can usually salvage a good one from an elcheapo lexmark inkjet multifunction.
Feb 11, 2013 | Samsung SCX-4824FN A4 Mono Laser Printer
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Hi I have a Samsung scx-4521F I am trying to send and receive Fax over IP now I know that I have to change the Baud rate to the lower one. but How can I do that? other than changing Baud rate what do I...
I have a samsung scx-4521f i am trying to copy some document but i cannot copy clean. my printer was copy in document black line or black paper ground what do i need to clean copy ? please help me.
Sep 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Copy is a black line
If copying from doc feeder the glass may be dirty. Run a copy on the glass if no line then clean the doc feeder glass.
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Vertical line down all copies coming from the top multipage feeder.
Please provide model number......however, if it's a "copier style" if you open the auto feeder, there should be a large contact glass and then a small "****" glass on the side that is used when using the auto feeder -clean this glass thoroughly (clean both while you're at it). If it's just a regular style fax machine, there will just be a small glass under the cover that needs to be cleaned.
Please let me know :)
Apr 21, 2009 | Office Equipment & Supplies
Samsung scx-4521f lines on feeder scan
Youll find that the most common problem with fax machines is that the scanner head that the paper passes over actually gets gritty and dirty. Remember it only takes a spek sitting in there.
Try a damp cloth (not to much Water) and wipe down the sensor reader, It will take a little bit of trial and error but mainly this is the common problem. also try wiping down all the wheels and rollers that the paper runs over as well. Otherwise it could be the recieval end that has a dirty paper feed wheel.
Sometimes it is also common that the internal scanner/sensor reader wears out and needs replacement.
IF this is the case its generally cheaper to buy another fax. Hopefully the above helps for you so you dont have to buy another one
Cheers
Steve
Apr 01, 2009 | Office Equipment & Supplies
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
213 people viewed this question
jasbo
jasbo
