Nothing works. Have followed the instructions to disconnect from the power supply for 1 minute. Power on lights up, when reconnect. No response to remote control,
  • 11 more comments
  • f_reitsma Feb 06, 2010
    Have changed the batteries again with new proven ones, unit does not respond.
    Brand is Scott Model MDX i65. It is a home audio DVD unit
    Cannot switch the unit off using the power button
    Cannot operate the unit with the buttons on the front panel
    Can I reset the unit, so it starts from the initial position? Deadstart
    Your analysis is probably correct. How Can I reset the unit?
    Are you also reading the user manual I have, or do you have additional info?
    Reset on the Unit by unplugging and plugging does not work, as I try to explain previously
    I expect that the unit has been exposed to a strong magnetic field. Same happened to a "atomic" clock in the surroundings
    Thanks for you help.
    Expert has been working on the base of the user manual plus his additional electronic expertise.
    Maybe another expert does have another trick to solve the problem
  • f_reitsma Feb 07, 2010
    Thx for your suggestion. Have tried this before but it is not the code controlling the remote control. This was reset to 00000 and worked after resetting.
  • 3,740 Answers
There is no make or model so we are winging it here.
What happpens in most remote control circuits is the following:
1. Batteries need replaced or battery termnals are corroded and need cleaned.
2, Keypad terminals in the remote are coated with some foreign matter be it body oil or something from food causing sticking keys or non functional keys. The remote key pad carbon coated rubber buttons and prinited circuit card must be thoroughly cleaned. The remote must be dis-assembled / taken apart to perform this task. A stuck remote control key from the introduction of foreign matter renders it completely non-functional.
3. A capacitor terminal has become loose from the remote falling on the floor or being dropped. (Will require a new Remote Control IC board)
4. The printed circuit board in the remote cracks from falling on the floor pr being dropped. (Will require a new IC Remote Control IC Board)
5. There is a problem with the IR circuit in the media center / reciever
Most of the time steps 1 and 2 will correct remote control issues.
If you need more assistance please provide your Make and Model.
Thank you for using Fixya.
Posted on Feb 07, 2010
  • 341 Answers
This is not really a solution but I would first make sure you have fresh batteries in the remote control and that they are installed correctly and if so you may have to search for a new code between the remote and home theater system. This you should not have to do, but it has happened to me in the past. Hope it works.
Posted on Feb 06, 2010
  • 10,594 Answers
What is model and brand of home theater system and did you replaced remote control batteries?
Let me know to find out possible solution.
Thanks.
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Feb 06, 2010
    OK, Can you turn is on or off from front power button of unit and can you operate it by front control buttons?
    If yes, then remote sensor sounds bad in your sound system.
    Let me know model and brand of your sound system.
    OK, that means system control chip is not working to accept remote signal to turn unit on.
    Qualified tech is required to inspect its internal circuitry.
    I do not see any reset button on unit.
    System control chip gets reset electronically every time when you plug unit in AC socket.
    System control chip requires 3 things to work, Volts supply, Oscillation and Reset command.
    All above you can check with schematics of unit and multimeter.
    I'm reading each word of your comments/ response and answering it accordingly because unit is not in front of me and your comments are feedback to diagnose/ analysis the problem.
    It is hardware failure in unit that requires to take apart unit for further circuit inspection.
    unit's own speakers also have strong magnetic field, I do not think that it can be cause of problem in this unit.
    No problem.
    Thanks.
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
Dell dimension 4600 led light comes on on motherboard but nothing else
That means that the power supply unit is OK. The problem lies somewhere after the power cord connection to the motherboard. do the following:- 1. Disconnect the power cord and reconnect. Reboot. 2. Remove the RAM DIMMS and reinsert and reboot. 3. Remove both the ends of the data cable of the HDD and reconnect and reboot. Make sure that the red strip on the cable is towards No 1 pin on the HDD. 4. Remove the processor with the cooling fan, reinsert and reboot.
Nov 21, 2009 | Intel Motherboard
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Gateway 510X H Desktop will not power up
Yes, definitely. You need to change your power supply.
Jul 23, 2009 | Gateway 510 X (10272197) PC Desktop
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
May 30, 2009 | HP Pavilion m7640n PC Desktop
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
82 people viewed this question
 Grubhead
Grubhead
