Question about Craftsman Single Speed Rotary Tool
My craftman single sped rotart tool the chuck with
Mycraftman single sped rotary tool, the chuck with bit does not turn and the units run like it did before. What could be wrong?
  • 677 Answers
Do you have any kind of a clutch on this drive ? I may be in bewteen settings.
Please let me know
Posted on Feb 06, 2010
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
How do i insert a bit? I've done it before, but so long ago I forgot and can't find the instruction booklet.
press and hold the small silver button near the front/end of the tool. This keeps the chuck/motor from moving. Use your wrench to then open the chuck and insert your desired bit. Tighten while still holding the button.
Sep 03, 2010 | Dremel Variable - Speed Multipro Rotary...
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
I have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
http://www.searspartsdirect.com
Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
Mar 16, 2010 | Craftsman Single Speed Rotary Tool
How to switch out bits on wizard rotary tool
1> UNPLUG THE TOOL to prevent any accidents
2>near the bit, there is a button. Push this button and manually rotate the chuck until it locks into place.
3>using the included wrench, turn the chuck counter clockwise until the bit is released.
4>reverse the process to install a new bit
5>make certain the chuck is tight so the bit doesn't come out during use
Oct 26, 2009 | Black & Decker Saws
BIT FALLS OUT/ WON'T TURN
try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Jun 20, 2009 | Bosch 11236VS Rotary Hammer
Bits will not lock into chuck
First I would go to Makitatools.com and download a schematic for this tool. But it is pretty simple to remove the rubber dust shield and plastic collar to look for debris and proper movement in the chuck assembly. Make sure also that you are using the right SDS bits in tool. You should be able to push the bit into the collar and twist until it goes into and locks. Let me know and I will help further
Jan 10, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Open Questions:
Craftsman Single Speed Rotary Tool Logo
158 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
