Question about Telex 4-52NH SpinWise CD Duplicator, Four Drive 52X CD Tower without Hard Drive (452NH, 4 52NH) (452NH) Burner
Installing hard drive on this model
Can i install an internal hard drive on this model. it looks like there is a place for it and there is an extra power supply plug-in.
    Genius:
  • 1,019 Answers
Sure why not.
You,ll need a ribbon cable also 40 or 80 strand IDE Cable. to connect from hard-drive to Motherboard. If you have an existing connector already in. this should be In IDE 1 Or Primary slot ( on motherboard ) there should also be a secondary IDE Slot.
connect ribbon to IDE 2 Or secondary slot, and to hard-drive.
ensure the jumper on the hard-drive is set to Slave Or Master, if your running another device from that same cable, set to Master/Slave alternate to hard Drive.
Good luck and go for It.
Power Off first.
Motherboards are,nt too happy about Static.
Mike @ compurepair.
Posted on Feb 21, 2008
I would like to fit a second hard drive i have a sata cable to go from mother board to second hard drive which i understand plugs into the mother board socket below main hard drive but their does not...
Look for more power connectors on the cables already powering devices. Especially check the entire length of the power cable terminating at your main hard drive. It is ok to use multiple connectors on the same cable simultaneously.
If you do need a splitter, I recommend this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812198015&cm_re=sata_power_splitter-_-12-198-015-_-Product
Mar 05, 2011 | Computers & Internet
I am trying to install a power supply for my Dell Dimesion 1100 desktop computer
The power supply is held in place by four screws. You will need a philips head (+) screwdriver for the job.
See this diagram as you read the description below.You will be using this diagram to identify different types of connectors... ignore any voltages or wire descriptions/colors that are there.
As for the wires, there are a few different types.
Main Power Connector You will notice a larger connector with 20-24 wires coming out of it. This will connect to the motherboard (and will only plug in one way). Notice there are two different ones on the diagram... one is 20 the other is 24... you probably require the 20 if I was guessing. If there is an extra bit on your connector (to compensate for 24 pin connectors), just ignore it... It will be fine just resting aside the others not plugged into anything.
Peripheral Connectors and Sata connectors
Your hard drives and Cd drives will either use 4-pin (four wires per plug, bout an inch in width) and will only plug in one way, or will use a SATA power cable which is also about an inch wide, will probably be black on the connector, and looks like it has an L shape inside it. These all just snap in place. Make sure each hard drive, and each Cd drive has a power cable going to it. (if there are multiple choices, it makes no difference, as long as everything has power.
If you have an after-market or third party video card (one that you have added or purchased separately) it may require its own power wire... This will (in most cases) be a four wire connector, and will plug into the edge of the video card. If you have not purchased a video card, this wont be a concern, as the default video gets its power from the motherboard its self.
+12v Power Connector
Lastly, there may be an extra power plug that goes to the motherboard (it will be four or six wires and will be arranged into a cube... unlike the hard drive wires which were in-line.) This four-wire square plug (or six wire) will plug into the motherboard somewhere near the processor.
Hope this helps!
Feb 25, 2011 | Dell Dimension 1100 PC Desktop
How do I plug in the new power supply on acer t135. more cords than places to plug them in
This is very common; the 'extra' connectors are provided for expansion purposes so as long as the devices presently installed are reconnected, you don't have problem other than finding a place for them so they do not interfere with fans, etc.
Feb 09, 2011 | Acer Aspire T135 PC Desktop
Any place to purchase a power supply for a WD element??
If you look at the Power supply box there should be a green light. If you unplug the cord and plug it in again it might just blink then stay our.. it is a common problem with these WD Elements. If it is newer, then it is under warranty.
How to check the warranty on a WD drive or product
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=915&p_created=1047361575
Title: What would void the warranty on my drive?
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=916&p_created=1048294698
If not they will sell you another one.
A replacement or extra power supply for your external drive can be purchased from our phone support team by calling 1-800-275-4932. Any technical support representative will be able to sell this part. Please have the serial number or model number of the hard drive ready, as this is needed to determine the correct adaptor type for the hard drive.
I hope this helps,
Randy
FixYa Support Team
Dec 28, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
I am trying to find were to put the new hard drive in the compaq presario 5000
There are several extra bays internal. You need proper data/and power cables, possibly a "Y" splitter to give you access to an additional power tap. Also about 4 small machine mounting screws and or spacer shims if the HD is smaller than the available bay. The HD does not necessarily need to be mounted through the front bt the 5000 has removable bezels that exposed the xtra bays.
Regards
Apeal
Aug 21, 2009 | Compaq Presario 5000 PC Desktop
Adding extra internal hard drive.
make sure you pc is turned off before you start. To add additional internal hard drive you will need to get SATA hard drive. when you open up your pc there will be a slot to put it in. on the new hard drive there will a display with shows you how to make that hard drive a slave. move the little thing to the right place and plug it in. when you restart it should read it .
Dec 16, 2008 | Computers & Internet
IO Magic Drive power replacement
All you need to do is ask at a computer parts store for an external hard drive enclosure.Take the hard drive with you and they will be able to give you the correct size, there are 3 sizes available, 1.8" (has a drive the same as an ipod in it), 2.5"(has a laptop /notebook hard drive in it), and a 3.5"(has a full size desktop hard drive in it).
The other option is you could just completely remove the drive from the io magic case and install it into your computer as an extra drive.
Jul 02, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Power supply installation in gateway 610xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Gateway Media Center 610XL PC Desktop
Replacing power supply on a gateway desktop 600xl
David
Feb 28, 2008 | Computers & Internet
Telex 4-52NH SpinWise CD Duplicator, Four Drive 52X CD Tower without Hard Drive (452NH, 4 52NH) (452NH) Burner Logo
57 people viewed this question
Top Telex Computers & Internet Experts
Longtime User
ray gallant
Tom Chichester
Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
