Question about Compaq Presario SR1000T (568657) PC Desktop
Blue screen crashes after adding new ram - Compaq Presario SR1000T (568657) PC Desktop
  • 163 Answers
Your computer may not support the ram.
Posted on Feb 06, 2010
Its common display driver problem i think. it fails with blue screen right before windows boot up. some say its because of overheat problem and other says its out-dated driver . windows 7 can boot up in...
try to open safe mode through F8 key
there r two solution's:
(1) Might be windows is corrupted that's why it shows blue screen before startup. Take ur data backup and reinstall ur OS.
(2) It's might be there is some issue with ur RAM. Remove ur RAM n gently n clean ur RAM with pencil eresar. Then reinstall it.
May 30, 2011 | HP iQ775 19" TouchSmart Desktop PC
Laptop showing blue screen when it loads
thats the blue screen of death generally its an issue with ur RAM try taking the Ram out n replacing it as maybe connection error if thats no help Replace it with some New RAM n will fix the Problem
Mar 22, 2010 | Computers & Internet
Hello I have an acer aspire 5535 and it keeps
The complete solution to this fault (Acer 5535 keeps crashing under vista) is to use Windows XP instead of Vista. Set up a Dual Boot so you can CHOOSE to load XP or Vista each time you turn on the laptop. I've put XP on my 5535 and it's SO much faster and seems perfectly stable now - no crashing at all.
A full video showing how to do this is here: http://www.youtube.com/watch?v=rdfU9TXIAd4
Once you've done this you won't have any problems with the laptop anymore.
This is a perfect solution to the crashing problem!
Jun 05, 2009 | Computers & Internet
Apple with newly installed RAM crashes all of the time
It's very possible that you got a bad DIMM of RAM if this started right after adding more.
If you have RAM from different manufacturers, even though it might be the right specs, and should work I've seen situations where the 2 DIMMS just don't play nicely together.
You can use a Linux LiveCD to test the RAM for defects. Just boot the LiveCD (holding the Option key after the chimes) and when you get to the grub screen select "memtest86". there are a ton of LiveCD's available. I would suggest Ubuntu.
If it turns out that the RAM is fine the tech will need more info to help although he/she should have asked some probing questions.
Doesn't anyone know how to give specific details about their issue instead of broad generalizations (it crashes) anymore...? :) Just playing...
"When" does it crash? Right after you turn it on? After 3 hours of usage every day (possible overheating)? What apps are you running when it crashes? Tell him "exactly" what it says on the screen when it crashes as it could be a kernel panic or a specific application causing it from the description given
I realize to a non-tech the perception can often be "This didn't start happening until you touched my computer" but realistically adding RAM, unless it's bad, won't cause that behavior as long as it's seated properly and the tech didn't forget to reconnect any fans, etc.
It would not be out of line to ask the shop to double check that the above isn't the case. Unless all of the above had already been double checked and confirmed they can't determine that "nothing's wrong".
I really do hope this helps anyone how has a similar issue and reads this.
Apr 03, 2009 | Apple Mac OS X 10.4
With blank DVD/CD computer crashes
My computer used to do this until I installed more RAM. Seems those video writing programs want to hog all the system RAM which causes the crash. I have at least 1 GB RAM minimum in all my computers. Hope this helps.
Dec 21, 2008 | ASUS Computers & Internet
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Pc crash
ARR THE BLUE SCREEN YOU MAY NOT HAVE ENOUGH RAM YOU SHOULD HAVE AT LEASE A GIG OF RAM - BUT SOMETIME IS CAN BE THE SOFTWARE THAT CORRUPTED THE WINDOWS SOFTWARE
Jun 25, 2008 | Asrock AM2NF6G-VSTA Motherboard
Crash dump blue screen
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her laptop and do a test swap to see if symptoms repeat. Then replace the ram. Far more common in HP's then Toshiba, but it happens for no reason. Basically it's a page in or out error with the ram causing windows to "freak out".
You can get a good selection of ram from Tigerdirect.com or newegg.com.
Apr 28, 2008 | Toshiba Satellite® P105-S6084 PC Notebook
Random freezes
blue screen means you have problem with your windows software or memory if you don't fix this soon it will not work any more until you reload the windows check your memory cards for good attachment
Dec 31, 2007 | Chaintech 7NJL3 Motherboard
Compaq Presario SR1000T (568657) PC Desktop Logo
85 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
