I was told what to do to fix my fan on my laptop, but i wanted to know if i could put my laptop over top a flat surface fan or on a table to keep it from overheating and shutting down until i get my compressed hair...
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and the complete make and model number of the laptop.
If the laptop is overheating due to failure or malfunctioning processor cooling fan, external fans will not be helpful to keep it cool enough to running for long intervals.
Thanks for using FixYa.
Posted on Feb 14, 2010
Hp probook motherboard
If the heat is excessive and/or shutting down because of heat issues, your fans and heatsinks might be dusty enough that they can\'t get the heat away fast enough. At the least, you should remove (or have removed at the repair shop if you cannot disassemble the laptop properly and/or completely) the cpu and/or gpu fans and heatsinks and clean them out with a can of compressed air. When they are removed, you should replace the cpu and gpu heatsink paste (non-conductive thermal compound) so that they can efficiently dissapate the heat they produce to the heatsinks. Also check your cooling fans for free spinning. Give the fan a clean, then try giving it a spin with your finger, it should continue to spin for a second or 2, the longer the better. If it stops spinning immediately, the fan might have to be replaced too.
If it runs, but gets hot ....
The following advice should be given to all laptop owners : the little rubber feet are important and should be replaced with something at least twice as high. Put your laptop on a flat surface, like a table, and look under the laptop. The little rubber feet give it airspace under the laptop, where most (but not all) laptops have the fresh air intake for the fans. If you cant see through under it, it wont get the cooler airflow it needs. A laptop cooler works best, but if you dont have a laptop cooler, you can use 4 plastic bottle caps (or similar) under the 4 corners to keep it up higher. And dont ever run the laptop sitting on a couch, chair, blanket, lap !! or any non flat hard surface, because the little feet wont keep it up high enough and the fan(s) will suck dust, lint, hair ... into the fans and plug up the heatsink(s)
Jul 16, 2013 | Intel Computers & Internet
My neighbor offered me a changing table but I don't really know what it is?
A changing table is usually a set of drawers that have a flat surface on the top where you can put your baby for diaper changes. They look like this:
n8anpp0jpakmwaaaabjru5erkjggg==
Aug 14, 2012 | Baby Gear
R61i overheats and goes in sleep mode
Many laptops accumulate dust inside the fan/heat exchanger assembly over several months or years, and must be removed in order for the laptop to properly cool itself. Depending on how much you use the laptop, it can happen in as little as a matter of months. You may want to ask a laptop repair place how much just to clean out the dust, and see if that works. Sometimes a cooling pad can help, especially if the laptop isn't already on a hard, flat surface.I actually keep my laptop on a small wooden board the same length & width as the laptop with a cooling pad on top of that, and the laptop on top of that, because I often want to set my laptop on my bed, which can smother the air circulation, and cause it to overheat quickly otherwise. Even when on a hard, flat surface, like a table or desk, if I am playing a game, I put it on the cooling pad because games cause the laptop components to generate a lot of heat, and this brand is somewhat notorious for overheating (especially when it has a discreet graphics card).
Mar 02, 2012 | Lenovo ThinkPad R61 Notebook
My laptop is over heating
Hi! first, i would like to ask if you are using cooling fan? if does, then i'll give you some tips on how to keep your laptop from overheating
1. Turn off your computer and allow it cool down.
2. Work with your laptop on a flat surface. The rubber feet on your laptop are designed to allow airflow to the underside of the computer, so if you are working on a bed or other soft surface, you cut off the airflow. If you do want to work away from a desk or table, try keeping your computer on your lap, exposing the underside to air.
3.Shut down your laptop before placing it in your carrying bag.
4 Give your laptop a bit more lift to increase the airflow under the machine. Two simple, flat rulers placed along the front and back edges of your computer is enough to increase the flow of air and keep your laptop cool.
5 .Unplug your charger as soon as the battery is full. A common mistake people make is leaving their computer plugged in at all times. However, the constant source of electricity will heat your battery and in turn overheat your laptop. Only charge your computer as long as necessary.
Hope this would be helpful.
Thanks for usinf FixYa : )
Sep 13, 2011 | Dell Computers & Internet
Hi we have a toshiba laptop model number psmc6a-003q00s. what's happening is the unit is over heating and cuts out having to wait to cool down and restart the laptop. sometime the fan kicks in but does...
Hi Danial and Gin a,
Your right! It IS Overheating. Usually this happens by using a laptop on a bed or soft surface that doesn't allow the heat to escape from underneath the machine. If that is the case. Use a desk or table top to place it on. Here is what can happen. It can keep overheating and then after it cools down one day, it may be finished and not recover. So it is a serious matter to correct as fast as possible. Laptop repairs can be quite expensive.
Cleaning out the fan is an excellent idea. I would go down to your local Walmart, or computer store and buy a bottle of compressed air type cleaner for computers. I would blow the dust out of the fan. The third thing I would do is purchase a laptop cooling device that sits under the machine and helps cool it with its own fans. If you do this you should come out fine.
If you have been using the machine on a soft surface, putting it on a hard surface and blowing it out may be all that is necessary. Good luck,
Best Regards, Mark
Dec 26, 2010 | Toshiba Satellite P105-S921 Notebook
My lap top keeps shutting down
This is normally due to it over-heating. It will turn itself off as a safety measure to prevent itself from becoming damaged.
Make sure the laptop is on a hard, level surface with nothing blocking the air vents.
Nov 15, 2009 | HP Computers & Internet
Vostro 1500 cooler fan problem
The fan only runs because the machine is telling it that it is too hot
Questions:
Is the fan running up to speed , are the fan blades dirty, is the outlet from the fans blocked , is the heatsink that the fans cool blocked.
Get a can of compressed air from your local Tandy if you are in the US or Maplins if your are in the UK
Take off the base cover (normally 4 screws) and give the fans a really good blasting and then do the same for the heatsinks etc.
Put the cover back on and try it , dont operate the machine on top of a bed or a table with a heavy cloth cover on it as that will impede the airflow
In extremes you can buy a cooler of Ebay which the laptop sits on and gets even more through flow of air
Nov 06, 2009 | Dell Vostro 1500 Notebook
Scratches / cuts in play surface
ok this Is A Very Very Easy Fix all you need is either carpenter putty or mighty putty and you fill the cracks and sand it down. therefore creating a smooth surface and if you want put gloss to make it slick.
Feb 08, 2009 | Harvard Xh 7000 Hockey Table
Computers & Internet Logo
David Payne
David Payne
