Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
Fuel pump vauxhall combi 1.7 diesel is their a pump in the fuel tank, am having probs with fuel not getting to the engine, its a v reg.
  • 3 Answers
No should be behing engine ,might be a faulty stop solenoid on top of pump.
Posted on Feb 09, 2010
Where is the fuel pump in a Vauxhall Vectra elite 06 plate
fuel pump is built into the fuel tank. in boot there is an inspection panel unscrew the screws to get to the tank housing. if pump not working it can be a bad connection or the relay in engine bay (pink on some models). check wiring to the connector on housing and its contacts, also in wiring is the fuel tank sensor wires.
Oct 24, 2016 | Vauxhall Cars & Trucks
How does the diesel fuel system work -does it have a lift pump
The function of diesel fuel system is to deliver the diesel fuel to the engine clean of of purities at the right pressure. In most generating unit diesel engines, the fuel system loop consists of the following major parts:
1. Day Fuel Tank
2. Fuel Water Separator
3. Fuel Strainer
4. Fuel Supply Pump
5. Fuel Filter
6. Fuel Injection Pump
7. Injectors
8. Return line to the day tank
Hope it can help you.
Maybe You Also Like: http://www.dieselgeneratortech.com/diesel-engines/basic-working-principle-of-diesel-engine-fuel-filter.html
May 13, 2016 | Cars & Trucks
I have a 2.2 vauxhall vectra auto which just won't go over 20 miles an hour engine seems to have missfire
Fuel delivery issue. Replace fuel filter inline. ...May need to replace the pick up screen in the gas tank on the fuel pump. price $12 access to in tank filter priceless.
Mar 18, 2016 | Vauxhall Cars & Trucks
Vauxhall combo engine in any gear when reaching 3000revs engine cuts down to half power returns to normal when restarted
hi,if diesel you probably need to change the fuel filter and when done try an injector cleaner in the fuel tank every 3 or 4 full tanks.
Jan 30, 2014 | Cars & Trucks
My vauxhall vectra 2 ltr di ,my diesel is not
As far as I'm aware, diesel is drawn from the tank, NOT pumped. The usual culprate is a rubber flex hose from a steel pipe attached to the engine bay bulkhead to the diesel pump. this could have split allowing air to be dragged into the system rather than diesel from your tank. If you pressurise the fuel tank and the car starts, this is certainly the problem. And if you're very lucky you'll be able to see where the leak is as diesel will be forced out of the split in the pipe also. Hope this helps :-)
Mar 25, 2010 | Briggs Garden
Fiat doblo 1.9 diesel year 2007. engine stop when low fuel tank
There is a possibility that your fuel transfer pump has quit and fuel is getting to your engine by gravity only. Have your tranfer pump flow rate tested. Also renew your primary fuel filter.
Mar 18, 2010 | 2007 Fiat X1/9
Low Fuel Pressure on Landrover Freelander TD4
From 53 reg onwards, diesel pump is under R.H. rear wheel arch, hidden by the plastic wheel arch liner. Older versions have combined fuel pump/sender in the tank (under R.H part of rear seat).
You should be able to hear a faint purr from the pump when ignition is turned on but engine not yet running.
Oct 07, 2009 | 2003 Land Rover Freelander
Unleaded Fuel in a Diesel Engine
You can buy a suction hose small enought to get intothe tank at an auto parts store. you will have to remove the fuel from the tank. All of it and then replace fuel filter.
Sep 21, 2009 | 2003 Isuzu Rodeo
Diesel engine, grey market kubota, the turqouise
yes there is a low pressure pump and a high pressure(incjector pump) if your no getting fuel to engine check for low pressure pump to be working may also have air in system which is very hard to get out and a diesel wont run untill most or all air is gone
Sep 05, 2009 | 1984 Dodge Caravan
How to check if fuel is getting to the engine
time to clean out the system
you should probably try running reg diesel through the lines
so drain the fuel tank and put some reg diesel in rem the fule line recently replaced and allow it to pour our into a bucket then after the fule starts running there then hook line back up and start pumping it through the injector pump remove 1 of the cylinder lines and see if you have fuel there using a clear hose and a bucket
attach hose to end of fuel injector line and see if it is pushing fuel through the injector body
remem ber you are still pushing reg diesel
now that the system is clean and clear hook all lines up and try and start the truck up on reg diesel
if it runs then your off to the races
if there is no fuel check the fuel filter it may just be full of gunk
or the pump might be cooked
but rem line b4 filter and check for flow
Aug 03, 2009 | 2007 Datsun 720
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
1,034 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Raymond Solomon
Level 1 Expert
Martin Clarke
Martin Clarke
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
