50 inch pioneer plasma power board.
Dan, the diode numbers are D188, D189, D190 and D191
  • 192 Answers
SOURCE: samsung 50 inch plasma
I have found the most common problems with the symptom you have described, to be the SMPS PCB. Sometimes the Y Main will cause the power supply to short out and lower a voltage in that area. Your set has a two year warranty. Call 1-800-Samsung to find an authorized servicer in your area.
Posted on Apr 08, 2007
Slinteriors
  • 8617 Answers
SOURCE: plasma tv parts
try pts corp. They have a huge inventory of rebuilt boards.
Posted on Mar 19, 2008
t0pc4t
  • 132 Answers
SOURCE: i heard a pop noise
The 'POP' noise was likely a capacitor saying farewell.
If you are able, AND confident with electrics - take the TV apart (UNPLUG)
These TVs are very heavily populated with Surface Mount components - I suspect that you will likely find - what looks like a small can (half a centimetre in diameter, with 'candyfloss' coming out of it..)
YES - You could get a replacement from somewhere like Maplin / Radioshack......
Replacement will work - However...you really need to establish WHY it went Pop, and get to the root cause (Excess power feed / drain)
Realistically - without sounding too negative . . other components would have also been affected but not necessarily killed.
Good Luck.
Posted on Aug 19, 2008
  • 2920 Answers
SOURCE: my pioneer 50 inch plasma
you have a weak power supply
Posted on Aug 28, 2008
bestdarngood
  • 3037 Answers
SOURCE: pioneer plasma 50 inch tuner
The power supply in the media box is usually the most likely culprit.
Dismantle the media box and remove the LARGE power supply board and check for dry solder joints. Where the heatsink is soldered onto the board the joints may be in a bad way. This is usually a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
Resolder the joints and you should be good to go. Whilst I can't guarantee that this is the definitive fix for this problem it seems to work for a while and is just a problem that many of these units have.
Posted on Sep 12, 2008
My plasma PDP-503HDE exploded: a saw a flash flollowed by some smoke and it doesn't work any more
hi,
You have to check the power supply board. Its a common problem with the power supply of the Pioneer PDP. As it is using smd coponnents there is no repair possible with the power supply . You have to replace the power supply board with a new one. You can find the part number in the board. Serch with the part number to find a new board.
OK
Sep 24, 2011 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer plasma tv had a power surge and now have flashing blue light
The power supply board is dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 26, 2011 | Pioneer PDP-5080HD 50 in. Plasma HDTV
I have a 50 inch pioneer plasma screen. I know the power board is bad, due to some blown components. What I don't know is what type of diodes to use. The board has alot of different ones, and most are...
What we need are the circuit designations for the parts in question. There should be a number on the PC board either nest to or under the actual part. Post those numbers here and I'll look up the parts. These should be Dxxx or ZDxxx or something similar.
Dan
Feb 05, 2010 | Pioneer Televison & Video
Hp parts
are parts for hp plasma tv as hard to find as ive been told need a y buffer upper board for 50 inch plasma
Jan 01, 2009 | HP PL4245N 42 in. HD-Ready Plasma...
Broken plasma screen on 60 inch pioneer, what to do can i repair it or only replace.
The plasma panel can not be repaired only replaced. If you post the make and model, I should be able to get you the part number and cost.
Dan
Jul 01, 2008 | Televison & Video
PDP-502MXE dead set
hi all,
this problem lis the power supply board. be aware that pioneer pdp-502mxe has got 3 versions and all 3 power supply boards are different so before ordering a new or reconditioned one check the part number on the power board itself.
pioneer is not replacing the boards anymore.
check on ebay.co.uk
i did sold so many parts from this model.
thanks
Jan 08, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Keeps switching off
Theres an power supply upgrade that Pioneer extended on most of their plasma models, even after your warranty is up. Contact them it cant hurt to try
Nov 17, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
