SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
SOURCE: Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
SOURCE: My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
SOURCE: directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
SOURCE: Problem with playback on DVR - R15-500 receiver.
Check your signal strength on your second tuner. Dont forget to check all satellites and, if you use the signal meter instead of system test, a few odd and a few even transponders.
It sounds like it may be low.
