Sherwood r-871 reciever audio works for 15min and then loose audio. video still works if you power down the unit for a min or so then audio works for 1 min then off
  • 506 Answers
There could be a cold solder joint somewhere in the audio signal path. Finding this will be a difficult task since you will need a schematic and layout. One thing you can try to do to find the problem though is get a can of freeze spray from an electronics supplier. When cold solder joints heat up they expand and break contact. When hit with freeze spray they contract again thus making contact.
Posted on Feb 11, 2010
I just came home with the sherwood am fm stereo reciever model no rx-4109 and connected speakers, but no sound is coming out
turn the unit on
press a button for am or fm
select a station frequency
still not working take it back for a warranty check / replacement
AFTER you have read the operatiors manual
Jan 24, 2017 | Sherwood Audio Players & Recorders
Why my sherwood 771 reciever turn on then right off
It is sensing a short circuit remove the short circuit probably the speakers to be disconnected and the receiver to be powered on if it does not turn off you have localized the short circuit
Jun 23, 2015 | Sherwood Audio Players & Recorders
RD-6506 sherwood back to standby mode after 3 second when attemting to operate the system, any help please.thanks and God bless
Hi,Need more info. Was the unit working then failed? tell me anything you noticed, this sounds like a fault in the audio output or power supply stages,I have had other receivers do this for variou reasons
Feb 27, 2014 | Sherwood RD-6506 Audio and Video Component...
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
I set the levels for all the speakers where I want them to be set at. But when I turn the unit off I lose all the speaker level settings and have to reset them
Some recievers have both a "power switch" and a "stand by" switch. Here is the difference.
"Power switch" eliminates all power input and most likely the memory in the unit too just like your stating in your situation.
"Stand by" switch shuts down all major components but keeps a small ammount of power to the unit to conserve any stored settings
Jan 05, 2011 | Sherwood RD-6500 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood rd7103 rec.
no listing for Sherwood receiver. must do the remote "search" function. here is how:
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope that helps!
Feb 28, 2009 | Sherwood RX-4103 Receiver
CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Sherwood RD-6108 Receiver
Sherwood 6500 reciver
check your speaker wires make sure they are not shorting against each other down the line, that will cause the reciever to go into standby.
Jan 25, 2009 | Insignia 200W Stereo Receiver
No power
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Sherwood R-945 Receiver
65 people viewed this question
 Grubhead
Grubhead
