Question about Galaxy Radios DX 77HML Base CB Radio
I would like to find the correct 2 digit channel display for the Galaxy DX77 CB Radio. The display in my radio has one segment out and can be confusing as to the channel you are seeking. Does anyone know where this item can be purchased?
  • 68 Answers
In most cases one of the 16 pins on the channel display has a bad contact, I have the displays in stock and ready to install if you need the work done.
Thanks,
Dodgem250.com
Posted on Mar 05, 2010
  • 5,603 Answers
I don't know whether this is an LED or LCD type. Finding an exact match would be difficult except from the manufacturer.
However, do CHECK the soldering of the display and the driver chip.
The segments almost NEVER fail on the LED. Soldering and board cracks and failed driver chips are usually more likely.
On the LCD displays, often they use a rubber strip with little wires to (looks almost like ribbon cable) contact pads on the glass from pads on the circuit driver board... THESE cause a lot of problems and often require a cleaning of contacts and the ends of the wires with isoprophyl alcohol and re-aligning.
Posted on Feb 06, 2010
How do I stop the frequency counter board in a DX-959 from loosing contact and making the display stop working?
You may have what we call a bad solder joint or a problem with the connection point from the counter to the radio. You need the expertise of a CB radio repairman.
Dec 08, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Dx44v frequency chart
first , Is this a new radio ? If it is then send it back to Galaxy .Its under warrenty for 3 yrs.Second if its not then make sure you are on the cb band . it should automatically display the frequencies.
Nov 01, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxy DX99V parts
how about galaxy.they still stock everything.
Mar 03, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy dx55hp stuck on channel 10.695
radio has a 3 yr warranty .send it back to galaxy
Nov 15, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Nov 03, 2012 | Galaxy Radios DX- 88HL Base CB Radio
I have a northstar 6000 with the channel display gone out! I was told you can not interchange with galaxy and can not get parts for northstar! Is this true?
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 08, 2011 | Radio Communications
When i turn on my connex 4800 dxl all that lights up is the power meter no chanel display or freq display no sound either
The voltage regulator on the right side of the radio (with the parts side up ) is located in between the 2 side screw holes is ether bad or the legs are broke loose . it is a A1869 transistor.can be replaced with a A473 Transistor . Basically it's the same as a Galaxy Radio ,Ranger makes the boards for (RCI ,Galaxy , Connex , North Star ,Super Star, General Lee .) Hope this Helps.
Oct 31, 2010 | Connex 4800-DXL 480-Channels Base CB Radio
2547 channel led is dim
This is a common problem with a lot of Galaxy, Cobra and similar radios. It usually occurs from one of two things the radio has been operated on a higher voltage than it was designed for ( Called Volting) and has damaged the LEDS or it can occur from poor connections to the display board either the 8 Volt line or the Grounds check for the proper voltage at the display. Note if you ground your meter somewhere besides the display ground you may get a correct voltage reading but still not have the correct voltage reaching the display so be sure to ground your meter at the display and read the voltage there as well.
Aug 26, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
Display lights go out after 30 seconds
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX 77HML Base CB Radio Logo
108 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
