The picture on the TV gets very dark when the power goes out
Every time the electric power goes out the TV picture is very dark when it comes back on. I have to use the on screen menu to get it to brighten up enough to watch. Why does it do this and is there a better solution? We live in the country and have the Dish Network.
  • Televison & ... Master
  • 5,056 Answers
It might be that it is going to a default setting when you lose power. See what happens if you select the default setting yourself. Perhaps there is someway you can get the set to except a new default setting?
Have a fiddle, see what you can come up with!
Posted on Feb 07, 2010
Fix led to with dark picture?
problem in the picture power board
take it in and have it fixed
May 23, 2016 | Televison & Video
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Turning off
Hi dcough2,
haev you tried to unplug it for some minutes, and then connecting it back again?
Anothwr thing to revise is if the socket is used for more than devices than the TV, it could also be weak power, so your TV image fait, or go dark, or it just shuts off because it have not enough power to use.
Jan 01, 2008 | Sharp Aquos LC-32D40U Television
Picture goes dark
1 your problem is in video section 2 if it is ok then check power supply for any components defective.
Sep 15, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
