Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I have a Brother's MFC-240C printer that keeps giving me a message of - Print Unable 4F See Troubleshooting and Routine Maintenance Chapter in User's Guide. I have tried everything the book says, which is to turn off the printer and turn it back on, then I even unplugged it. It was on my desk for 2 months unplugged and when I plugged it back in it worked for a week. The message is back and now I can't do anything. Help!!!
  • 677 Answers
Did you put in new Genuine Brother Cartridges?
NO GENERIC.................
If not, then do so. Maybe Ink Cartridges are dried out.
Good Luck.........
Posted on Feb 06, 2010
    President:
  • 2,306 Answers
The manual says that error is either the printhead gone bad or the main logic board. Either will cost more thana new machine. The head alone is over $100.00 and the logic board is twice that amount. I would get a new one and start again with a one year warranty.
2 Suggested Answers
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
Says unable to print 4f, see troubleshooting and routine maintenance. please help.
This is a print head failure of some type. Turn off the printer, disconnect the power cord and lift up the scanner unit. Check for any paper or foreign object. See if you can slide the printhead and check under it. If the printhead will not move easily, do not force it. If the printhead is all the way to the right, you will not be able to move it. Use a flashlight to check for any foreign objects or paper scraps soaked with ink. Remove any foreign stuff that you find.
Sep 15, 2010 | Brother MFC-5460CN All-In-One InkJet...
Brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Jan 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
Unable to print
i think your printer needs a clening
i hope i can solve your problem
Sep 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to print See Troubleshooting and routine maintenance chapt
Open the top cover and hold the interlock switch on the top right hand corner. Power up and wait for the carriage to come to the center. Shine a flashlight all the way to the right and left and pull out the crumpled paper. You should be able to print again..
Aug 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable 36 error
The 36 error mean: The machine does not work due to a paper jam. Clear the paper jam, if doesn't work maybe a sensor is dirt or bad. To disassambly the printer you need the service manual and some know how ( electronics knowledge).
All the best !
Feb 21, 2018 | Brother Multi-Function Center MFC-240C...
Unable to print
ph is defective and needs replacing (4F: thermo sensor within ph)
Mar 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
395 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
