Question about Hitachi 50DX01B 50" Rear Projection Television
Best way to get to the fuse. TV will not power on
Where are the fuses in my tv
The fuse of your tv is located in the power supply if you remove the back cover of your tv you just follow the ac cord this ac cord is attach to the power supply and you will see the fuse there, this is the picture of a fuse.
hope this may help good day and best regards.
Sep 16, 2011 | Toshiba Televison & Video
WE HAD A LIGHTING STORM AND I HAVE NO LIGHTS ON MY BRAVIA WILL NOT TURN ON IS THERE A BREAKER OR FUSE TO LOOK FOR
There is a fuse in the tv power supply board,a fuse it is located near the a/c socket plug in of the tv power supply board.Lighting storm pack a huge anount of power and magnatic static field.If ur tv was in that path.U will not fixed it with a new fuse the tv whole power board probally dead already and those other circuit boards on the tv might be dead too.Good look with the replacement of the fuse,maricles might happen ur tv just have a dead fuse only.Not must take to or call many tvs shops and get the best estamates prices to fixed the tv.Not a do it self project,if tv a got hit by a massive power surges.
Aug 11, 2011 | Sony BRAVIA KDL-46V3000 Television
After a lightning storm, my TV will not turn on. Is there a fuse or something on the in coming power that may have blown causing it not to turn on?
Any TV subjected to a power surge will have problems. If you can remove the back cover, do so. Locate the glass fuse. In the best situations the fuse is clear and opened, and replacement will repair your TV. In worst cases the fuse may be blackened, and you will see that many components are burned and shattered. If this latter is true, only replacing the TV is your best bet. In many cases electronics may be connected to surge protectors, but lightning will over ride these devices and cause damage. I have seen this happen many times.Thanks for asking and show all hands of support!
Jun 23, 2011 | Sanyo AVM-3659S 36" TV
Tv does not turn on , there was a power outage and since then it wont turn on. there is power to the outlet
If the TV is completely DEAD. Check the main fuse in the power supply. Replace the fuse with exact amperage. Make sure you unplug the TV before taking the cover off. If the power supply keeps blowing the fuse, replace the power supply. Be very careful high voltage can kill!
Best of luck
AAA TV SERVICE
Jun 12, 2011 | LG 42LG30 42 in. LCD HDTV
How would you test the power supply blacklight inverter borad to find out why it is blowing the fuse.
If you can find the connection that actually connect the lighting system, this will remove the load and the fuse will remain good. Better still run a voltage check across the fuse line with a DMM, to save further damage to the TV. At best replace this power inverter board!
Jan 10, 2010 | Emerson LC320EM8 32 in. LCD TV
Power board in magnavox 37MF231D blows fuse right away. Caps are good on board and fuse still goes when disconnected from TV.
Then you have a shorted regulator circuit. the best bet is to replace the power supply board itself. The part number is 313815864961. Please take a few moments to rate my answer, Thank you.
Nov 17, 2009 | Philips Magnavox 27MS343S 27" TV
I have a mitsubishi screen tv model# WS-553115. No power? I pulled the cord out of the wall when the tv was still on. What do you think happen?
hello it sound like you could have blown the glass fuse in side the tv. in the power supply you should see a glass fuse just replace it. but make sure the power's off all the best
shaun
Oct 15, 2009 | Mitsubishi Televison & Video
I plug my tv into the power point and no standby light or anything comes on.
hello have you checked the fuse in the plug if thatssure ok check the glass fuse in side the tv if its blown make sure you put the same rated fuse back in all the best
shaun
Aug 04, 2009 | RCA Televison & Video
Red power light is unlit, TV is unresponsive
This has most probably blown an internal fuse in the power supply. Most have a surge protection type fuse. It is best to have a repair engineer have a look at it as the fuses are specially rated for safety.
Mar 28, 2009 | LG 42PC5DC 42 in. Plasma HDTV
My tv did not come back on after a power cut could it be the fuse
Good Day;
After a power outage it is best to 'reboot' the TV. Unplug the TV for 4-5 minutes from a/c outlet, wait, plug back in. Did not work?
It could be the main fuse, it will be located near the a/c cord on the TV's board. CATION!! After removing back of unit make sure the TV is unplugged from the a/c outlet and the fuse will be a glass fuse, ensure that it the correct value eg; 5 amp 250v.
Good Luck and Careful, Big Irish.
Jun 18, 2008 | Televison & Video
Hitachi 50DX01B 50" Rear Projection Television Logo
14 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
