Question about Dell E173FP 17" LCD Monitor
My monitor is brighter on the lower left side than on the rest of the display?
  • mr_ibanez Feb 06, 2010
    the self test feature check works but its like the black screen goes from black on the upper right to gray fade towards the lower left
  • Dell Master
  • 1,183 Answers
NOTE : steps below are only for a Dell monitor
There could be two reasons for the same,
1. The monitor settings are bad or
2. The monitor has gone bad.
Request you to disconnect the monitor signal cable from the back of the computer (cable with the blue jack)
A self test feature check would run on the screen. If the screen is bright in the feature check . The monitor has gone bad and needs a replacement.
If the screen appears ok in the self test . Press the menu button on the monitor and select factory reset.
Thanks
Proton
Posted on Feb 06, 2010
  • Mandeep  Singh
    Mandeep Singh Feb 06, 2010
    If the color is changing on the different areas of the screen. The screen would have to be replaced.
    Dell generally gives 3 yr. warranty on there flat panel monitor. If you have bought the monitor separately from the computer.
    Thanks
    porton
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
I have a SyncMaster 225bw, approx 3 years old but havnt used it much in the last year and a half. it started having a problem starting back up it seems. if i can get it to stay "lit up" it will...
This type of monitor problem is usually cause by a failure of the capacitors in the power supply board. What is happening is the power supply is not starting up correctly so the back lights are not coming up to full brightness. Here is a link to a repair guide that will show you how to dis-assemble the unit and repair the power supply board. http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
If you can do a little soldering then you can do the repair yourself.
Apr 15, 2011 | Samsung 225BW LCD Monitor
I washed it using bit of water n now some of the monitor display is more brighter than the rest.
seems u got it messed up...water is the enemy of TFT/LCD monitors....
once it seeps in they spoil all the diods and circuits in them
Jan 22, 2010 | Acer AL1702WB Monitor
Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Sep 22, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
MONITOR DISPLAY PROBLEMS
the display has a loose connection in every side. try pressing the both side by hand.
Jun 14, 2009 | Computers & Internet
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Brighter rectangular area in the centre of the screen.
it's a software problem, philips 109s has got a software that can make a selected area more brilliant than other, try to overwatch what you have open in you system tray..
Dec 14, 2006 | Philips Brilliance 109S Monitor
Dell E173FP 17" LCD Monitor Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
