Agitate water sitting in drum and will not agitate
  • adam tech May 11, 2010
    what make is it?
  • 714 Answers
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Posted on Feb 07, 2010
Hi I have a Bosch Avantixx6. On woolen wash it fills with water and then just sits there doing nothing????? Janet Bournemouth
My Bosch machine has very little drum movement on the woollen wash, I guess because woollens shouldn't be agitated too much.
Aug 15, 2016 | Bosch Washing Machines
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
This is for an LW7503W2B washer. We have water on the floor during agitate with large loads. The water is comming over the edge of the tub. I have noticed the tub rotates in what I would call a slow...
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Oct 18, 2010 | Amana ALW780QA
Have a Kenmore Elite top loading machine and the water starts to fill the drum and it empties out as it fills, so the drum only fills half way. No agitation or spin. Because it just sits there with the...
this sounds like the fill up censer is blocked up,,,its a cheep fix,,, its only a pipe that fills with water and at a set point it stops filling the washer, but if the pipe is partly blocked it throws its self into a wobely?? and thinks its over full so it starts to drain this water out
a good pear of lungs should blow any muck out this pipe
Jun 06, 2010 | Washing Machines
Can't remove agitator
Get 2 2x2 pieces of wood or 2 oak handles, 20 inches long. lay on on top of the other on the top of the washer. Loop a rope or ******** both sides of the agitator over one of the pieces of wood and tie it to the top piece of wood. Twist the top piece of wood slowly. As the 2 loops tighten up under the agitator the bottom piece holds the rope firmly across the top of machine. This save you from getting socked in the face by the agitator when it come off. You can buy an agitator remover but why not make you one and have so much fun doing it See the pic below? just ease a stick above the 2x4 and start slowly twing till she jumps out. Note: I didn't make this design I found it on line. I would run the rope under the agitator instead of taking a chance on breaking the fins. But that's just me.The trick is to grab it by the neck instead of the base. So try that before concocting a agitator remover. The agitator just snaps on. The drive block under the agitator is stripped out Wh43X10009 91c45a0.jpgis the part number. Here it the manual3c3b88a.jpg
May 25, 2010 | GE Profile WPSR3100W
It washes and agitates fine but when it's time to let the water out it just sits there and does nothing, the knob will move to rinse and then shuts itself off
Pump blocked or clothing down in hose
Remove the water from the machine by putting the drain hose down into a bucket
Either open the lint trap to check the pump or remove the hose which comes from the drum to the pump
Apr 01, 2010 | Tecnik TKL9260 Front Load Washer
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Just out of storage, my washer is having difficulties.
Hi, There are capacitors that give an initial boost to start the motor moving and these tend to go bad from sitting for long periods, that's why you could give it an assist and it would work, you are providing the extra boost. Helping it though causes other problems, like belt and voltage control problems, so that is not a good idea. You should have it looked at if you are not electrically or mechanically inclined. Best of luck to you!
Feb 13, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
