Question about Canon GL2 Mini DV Digital Camcorder
Little flashing red symbol with a diagonal line through it and a + sign above it on my camera lcd screen...? camera seems to be working - not sure if this is a setting of some sort...??
    Sergeant:
  • 166 Answers
Telling you the Clock Battery is dead. There is a little grey door inside the LCD screen cavity. Takes a 2025 coin battery.
Peace
Posted on Feb 27, 2010
Hi, I see a flashing red symbol very small rectangle looks like it has a diagonal red line through it. it is on the lower right side of my screen, above the area where the symbol for "remote"...
try to reset it by taking out the battery for a few min. then put the battery back in an turn it on. if that don't work go to www.canon.com click on Brochures & Manuals an down load the manual for your canon free.
Jun 07, 2011 | Canon Elura 100 Mini DV Digital Camcorder
I get a flashing red warning symbol during play and record. It is on the bottom LHS of the screen just above the 'camera shake' indicator and looks like an oval with a back slash through it. This symbol is...
i think it's the button cell that's CR1616 that's hidden when your battery is in the camcorder. Remove the battery to reveal that little plate to replace your button cell. It functions properly just that time and date might not be recorded.
Jan 02, 2011 | Canon MV940 Mini DV Digital Camcorder
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
I have a zr100 camcorder and I have a red flashing icon underneath the battery icon. It looks like a boat with a diagonal line through it with an arrow to the right of the line.
On page 24 of the manuel it shows the symbol that you mentioned below the battery symbol. It's labeled item 4. Which states "flashes in red when the lithium button battery is not installed, or when it needs replacing". I guess you need to check the lithium battery with a voltmeter to see if it's any good.
Dec 04, 2009 | Canon Video Cameras
No Flash
Is there a symbol on the screen of a lightning bolt in a circle with a diagonal line going through it? If so, your flash is turned off. If not, maybe the pictures you're trying to take don't require flash. Do they seem to coming out ok?
Sep 07, 2009 | Vivitar ViviCam 35 Digital Camera
Flashing symbol
This symbol means that the backup battery needs to be changed. The backup battery is a button-type battery, CR1616. It is located under the main battery behind a small square panel. Instructions for changing it are in the manual -- look under "backup battery" in the index.
Apr 06, 2009 | Canon MV800i Mini DV Digital Camcorder
Flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
Feb 22, 2008 | Canon GL2 Mini DV Digital Camcorder
Flashing warning
Your CR1616 battery is not installed properly. +sign to +sign
lockwood.b@sbcglobal.net
Dec 22, 2007 | Video Cameras
Camera turns off
the red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
Nov 04, 2007 | Panasonic NV-DS65 Mini DV Digital...
Canon GL2 Mini DV Digital Camcorder Logo
656 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
