Question about Dryers
How do i repair my maytag from squeeking - Dryers
  • 10,319 Answers
Remove the front exterior panel. The seal around the drum must be clean and have no crease. If so the seal will produce a sqeek. Also the belt around the drum must be tight and the roller bearing on the belt tensioner must turn freely. If the roller is out of round the drum will rumble and if the bearing is dry or jambed the dryer will sqeek as well
Posted on Feb 06, 2010
Maytag clothes dryer has squeeking/screeching sound when it is running/going.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 03, 2011 | Maytag Dryers
Dryer makes a squeeking,or "chirping" noise while
Most likely the problem is the drum rollers are in need of lubrication.
Lube the drum rollers and this should solve your noise problem
Jan 05, 2011 | Maytag MDE9700AYM Electric Dryer
Maytag clothes dryer making squeeking noise?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 24, 2010 | Maytag Dryers
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Maytag MDE5000 squeeks while running
hahhaha your celfone is ******* noob bulshit ************
Mar 29, 2009 | Maytag Atlantis MDE5000 Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
105 people viewed this question
Top Dryers Experts
