Question about Kenmore KSM100 Stand Mixer
Cold and hot water are mixed up.
It's the Kenmore 600 washer series, and sometimes when set for the hot water temperature, cold comes out instead and vice versa.
I just purchased the same model and have the same problem. Call Sears and have a repairmen sent while still under warranty. The water temperature sensors needed to be replaced in my washer.
Posted on Feb 11, 2010
  • 110 Answers
Check to see if you put the supply hoses on the wrong inlets to the soleniod fill valve on the back of the washer
Posted on Feb 06, 2010
Bowl knocks while mixing and seems like it should fit more securely
If you mean bowl knocks against the mixer, move the round plate a notch on the right.
Nov 26, 2013 | KitchenAid KP26M1XER - Professional 600...
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
My refrigerator is not getting cold,but the freezer on top is just fine,How much will this cost to have a repair guy come out?
you need to check if the evap. fan is good maybe not spinning to circulate cold air into the fresh food compartment(i.e.refridgerator
Jul 11, 2009 | Kenmore KSM035 Stand Mixer
Mixing attachment for stand mixer is stuck
I had this happen today. I took a towel and covered all of the beater except where it attaches. I sprayed WD-40 on it. This loosened it and it came unstuck. Then I washed it thoroughly with hot water and soap. It had some dried batter stuck inside which caused it to stick. Guess I better pay better attention to how clean I get it inside. PS Don't spray WD-40 anywhere else - this is something you make food with!
Mar 28, 2009 | KitchenAid KP2671 Professional 6 Series...
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
I was kneading dought with my professional 600 and it stoped all of a sudden...there is a smell from the moter
when the kitchenaid overheats when mixing dough many times its just the thermister that has blown. This part is available from radio shack for about$1. 125v 135-150 degrees. just repace it and you may be in luck. the thermister acts as an overload fuse when the motor get bogged down and overheats instead of the motor blowing the thermister blows to protect the motor.
Dec 05, 2008 | KitchenAid KP2671 Professional 6 Series...
KSM90 Kitchen Gets stuck in the middle of mixing Bread Dough
Hi
If you decide to get rid of it can you sell the accessories parts?. I have one with no parts.
Thanks,
Barak
baraksch@nana.co.il
Nov 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Bosch universal mixer
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
May 29, 2007 | Bosch MUM6630 Universal Series Stand Mixer
Kenmore KSM100 Stand Mixer Logo
271 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
john h
NOEL
NOEL
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
