Question about RCA P52926 52" Rear Projection Television
I have a 52rca the screen is broke Where can I find another sceen
The screen broke into 3 pieces. Its a 2001 model please help.
Sceen is on, sound is on,but imegen is not, this is a phillips 47' lcd tv can someone help me is like 4 years old
That could be a Tcon or a main board issue. Can you post a picture of the screen? also will need the model number. Please respond to this same post for further assistance.
Jan 01, 2013 | Televison & Video
The picture went from full sceen to half a sceen. how do i get it back to full sceen.
need the model number of the set and also is it half the screen left or right or half the screen from bottom to top
Dec 30, 2012 | Televison & Video
Screen is broke
type name of model on ebay.com and size to see if they have a replacement screen should be kinda cheap
Feb 25, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I need the dash board piece that goes around the radio. a piece broke off and i wan to replace the piece. where can i get it?
Call around the local salvage yards. You should be able to find one very cheap.
Please rate this if it helps you! Thanks!
Jan 25, 2011 | 2001 Mercury Cougar
Iv Changed My Phone Case From Black To white iv by mistake broke the ribbion that holds the LCD sceen. i cant get my touch screen to work HELP !!
simply chane your touch screen . hope it helps. because anything that is damage which is used on the processing of the response on the touch screen. it would impede the normal response of your phone.
Aug 06, 2010 | Nokia 5530 XpressMusic Smartphone
Broke screen
The mirrors are just mirrors, any paint/glass store can get new ones cut for you if you take the pieces of the old one in. The screen is going to be a hard one though. Actually if you can find (which I am sure you will be able to) another broken tv, very seldom is there any damage to the screen itself. There are two parts to the actual screen though, a tinted piece that dims the picture and a frosted piece that catches the image. Good luck!
Jun 12, 2009 | Sony KDF-E42A10 42 in. LCD Television
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
52RCA
This is probably the High voltage splitter arching.
Pretty cheap part from Matt electronics
part# 205064 --- $22.50.. Look and see if you find any oily substance leaking down on the yoaks.. If you do you have a bigger problem
Feb 18, 2009 | RCA P52926 52" Rear Projection Television
A piece broke
I just purchased this crib from craiglist for my daughter and future grandson. We broke the plastic track assembly on the lower left front. I just now called the customer service number and they are sending me the complete assembly and when I told her it had one stripped out bolt, she is including a complete hardware package. Didn't cost me one penny! Now that is true customer service!!!!! This is for the 3 in 1 sleigh crib, Model No. DASE5009. The customer service number is 800-295-1980. Their hours are 8am - 5pm est M-F. Hope this helps!
Jan 24, 2009 | Dorel Alexander
My sansa e260 is broke.. HELP ME PLEASE!!!!
you have 2 things to do : 1- if you have the warranty you could exchane it. 2- Go to an lectronic store and buy the screen seperately, take the first one off than put the other one.
Mar 02, 2008 | SanDisk Sansa e260 MP3 Player
RCA P52926 52" Rear Projection Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
