Question about Jabra BT150 Wireless Headset
Switching off the headset
When headset is on, I press (and hold) the (flashing) button .... but it just keeps flashing and not turning off!
    Novelist:
  • 141 Answers
You need to hold down the button til it turns off. It takes a couple of seconds.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for the manual
Posted on Mar 29, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
I can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
As of 2012: the button to hold is POWER.
1. make sure HS-905BT is off (hold Power till the blue light goes off, you hear descending sequence of tones)
2. hold Power to turn on (ascending tones, blue LED on) + KEEP holding Power till the blue LED flashes twice and you hear a double-beep. Device is ready for pairing.
Jun 02, 2012 | Radio Communications
Cannot pair with my cell phone
. Make sure the Bluetooth Headset is turned off.
2. Keep your Bluetooth Headset and mobile phone within 3
feet of each other during the pairing process.
3. Press and HOLD the [POWER]button until the RED and BLUE
lights flash alternately.
NOTE: To enter the pairing mode, you must press and HOLD the
power button for approximately 10 seconds
Good luck
Hope it helps
Thanks
Please rate FIXYA
Apr 18, 2011 | Plantronics Explorer 320 Wireless Headset
How does one turn on a Motorola 537w bluetooth
To power your headset on, press and hold the Multifunction for 3 seconds until LED flashes rapidly.
To turn your headset off after use, press and hold the Multifunction button for 3 seconds until the headset flashes rapidly and turns off.
Hope it helps
Apr 16, 2011 | OEM Systems Motorola Bluetooth Headset ,...
Htc hero not pairing with plantronicc voyager pro. Is serching but not finding headset
Thanks for visiting FixYa!
How to Pair Your Headset with Your Phone for the First Time
1 Turn on your phone's Bluetooth feature.
For most phones, select Settings/Tools >
Connections > Bluetooth > On. See your
phone's user guide for more information.
2 Turn the headset on.
Press and hold the power button until the
indicator light flashes red/blue. The headset
is now in pairing mode.
If you don't see the red/blue flash, press and
hold the power button to turn your headset
off, and then press and hold the power
button again until you see the red/blue flash.
Pairing Your Headset
3 Use the commands on your phone to
locate your headset.
Devices > Bluetooth > PROPlantronics.
See your phone's user guide for more
information.
4 If prompted for the Passkey (PIN code),
enter 0000.
Pairing is successful when the indicator on
your headset flashes blue. Your headset is
now connected and ready to use.
Apr 02, 2011 | Cell Phones
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
Samsung wep410
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Jan 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Jabra BT150 Wireless Headset Logo
60 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
